RETIRED
Joe Bob's Avatar
My first 3.2, starting issue
So....cranking the motor, starts and immediately dies.....what do I adjust?
Stepping on the throttle while cranking does nothing....bump starts and runs immediately....
2012 ML350 3.0 Turbo Diesel
Old 09-03-2006, 02:13 PM
Diss Member
Quicksilver's Avatar
You don't have it listed so not sure if it is a stock Carrera, something with a stock Motronic driving it, or some sort of Frankenstein abortion thing with carbs, MFI, or CIS on it...
One thing is that a Motronic car is supposed to be started with no throttle input. Just turn the key.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 09-03-2006, 03:05 PM
RETIRED
Joe Bob's Avatar
Yep....it's stock...but it's in a 914/6. LOOKs like I have it narrowed down to an issue with the ignition switch.
Old 09-03-2006, 03:31 PM
Autobahn Garage
DME relay??You may want to check into that I have replaced those to cure the same problem
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 09-04-2006, 05:13 AM
