Send a message via AIM to Brandon Sincock
Alternator Model?
Is there a way to figure out what kind of alternator I have on my car without having to pull out the fan?
I need to replace my Voltage Regulator and the current VR is a no name unit.
I've read that the VR must be matched to the Alternator in order for it to function properly.
Here's some pictures of the bad VR:
Thanks.
Brandon Sincock
70' 911T Targa
Old 04-20-2006, 03:26 PM
Early_S_Man's Avatar
Porsche Crest
Brandon,
That isn't any OEM Voltage regulator I've ever seen, i.e., it isn't Bosch or Motorola/Marchal!
Remove the alternator nut and measure the shaft threads ...
M14 x 1.5 = Bosch
M16 x 1.00 = Motorola/Marchal
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 04-20-2006, 05:02 PM
Thanks for your help.
I'll give that a try.
Is the best way to get those measurements a micrometer?
Brandon Sincock
70' 911T Targa
Old 04-20-2006, 05:33 PM
Porsche Crest
Brandon,
It doesn't have to be a micrometer, any kind of caliper, or even a ruler will do ... if you eyeball it carefully, for the major diameter. For the thread pitch, you can use an M6 bolt with 10 mm head as a gauge ... if it matches, then the pitch is 1.0 mm. A CV-joint bolt is M10 x 1.5 ...
Warren Hall, Jr.
Old 04-20-2006, 05:52 PM
avendlerdp's Avatar
Brandon,
I have a pitch guage. Call me.
Alex
1972 Porsche 914 Project
2000 BMW M5
1973 Aermacchi 350
Old 04-20-2006, 10:29 PM
Thanks Alex!
Looks like I owe you another lunch.
Brandon Sincock
70' 911T Targa
Old 04-21-2006, 12:30 AM
Jerome Ryals's Avatar
I took my '70 e on a 400 mile road trip over last weekend and a few miles before I got home my alt lamp started to glow, looks like I'll be into that this weekend, I'll see if I can get a pic to you of my VR, read the 101 book last night on alt replacement to get prepared -the local parts place lists a variety of amperage alternators for that year? Anybody out there know what a 70e would use has power windows, AC, sunroof, fog lights.
Old 04-21-2006, 04:38 AM
304065's Avatar
1970 E = 55 amp Motorola/Marchal.
Jerome, avoid the temptation to bump up the amperage unless you have a spare fan shroud handy, the later alternators don't fit in the early shrouds.
If you don't mind spending some extra money you may consider the Bosch reproductions from AASE sales or this website, these are higher power and fit in the early shroud.
Good luck!
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 04-21-2006, 05:13 AM
THANKS for that piece of information John, I sure didn't know that.
Old 04-21-2006, 07:32 AM
