MOMO3.2's Avatar
Stubborn Fitting Prototipo
I am having a heck of a time trying to fit the Momo Prototipo adapter hub to the splines on my steering shaft. I have a 1987 Carrera. The Momo Hub adapter is part #4005-L231. I put a thin layer of grease on the hub splines and the shaft splines after to help things along. This did not seem to help much. I have been beating on the inside of the hub using a large deep socket and rubber mallet. I can get it to the point where there is a bout 3/4 of an inch to go and that is it.
My original wheel fits right on. It does not look as though I am damging the splines on the shaft or the recepter splines on the hub.
Has anyone else run into this problem?
Thanks.
Mike
Old 04-21-2006, 06:33 PM
I temporarily bolt the steering wheel to the adapter and then use the steering wheel as leverage to push it onto the splines.
Old 04-21-2006, 06:42 PM
Nobody
bob tilton's Avatar
I have heard of people using a triangle file to debur the hubs. I understand that it just requires a delicate touch.
Bob Tilton
www.werkcrew.com
Old 04-21-2006, 06:45 PM
Hey Bob - check the Early S board. Cornpanzer needs to talk to you! -- Curt
Old 04-21-2006, 06:47 PM
jackb911's Avatar
Hi, Mike,
Try putting a thin coat of wheel bearing grease on the hub and steering shaft splines. The last Momo I installed was tighter than usual, and this worked for me.
Jack
2007 GT3
gone but not forgotten: 1987 Carrera IROC backdate, '89 Carrera M491, '96 993, '93 964 RSA(two), '00 996, '97 Boxster, '79 911SC, '78 928, '76 924, '75 914, '74 911, '74 914, '72 911E, '72 911T/V, '71 911T, '70 911T, '66 912, '65 356C, '61 356B roadster, '60 356B
Old 04-21-2006, 08:25 PM
MOMO3.2's Avatar
Thanks all.
Jack, I tried Grease right off the bat and it is a no go.
Bob, I am going to carefully file the slines on the Prototipo Hub. Thank you.
Mike
Old 04-21-2006, 10:09 PM
