Clutch release fork - Do I need one?
How do you know if you need a new one of these?
http://www.pelicanparts.com/cgi-bin/smart/imgdsply.cgi?pn=91511671201-M260
Engine is out and I am doing the clutch (915 Transaxle) as well as a general clean up and new seals everywhere. My release fork looks good with no wear but I am wondering what determines if it needs replaced. Help?
Thanks,
Old 04-24-2006, 07:12 PM
If there is not excessive wear and no cracks (inspect it carefully) then reuse it.
Old 04-24-2006, 07:15 PM
cantdrv55's Avatar
I replaced mine because I read somewhere that it's a good thing to do while you're in there. The old one had nothing wrong with it though so I think I may have just wasted $95. I'm with Jim. Inspect it very carefully and reuse it if all looks good.
Old 04-24-2006, 11:38 PM
I just splashed it with thinner to help find a crack.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-25-2006, 12:46 AM
SC Schrauber's Avatar
mine was good, so I reused it.
81 SC, www.frankschroeter.com
Old 04-25-2006, 03:27 AM
the tips get notches worn in them from pulling on the T/O bearing, and they tend to crack, so there's two reasons.
206 637 4071
Old 04-25-2006, 08:07 AM
na2ub's Avatar
I had my whole clutch re-done after 20,000 miles because my fork cracked. Save yourself some headache.
Doug
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 04-25-2006, 09:12 AM
Replace it!
I had a new clutch and T/O installed 5k miles ago.
Now I can't shift into 1st and we think a broken fork is the culprit.
Old 04-25-2006, 09:39 AM
In a 1973 T with a standard pressure plate and nominal engine (130 or 140 horsepower tops) the shift fork is not a highly stressed component; if it isn't worn or cracked it can be reused. Money would be better spent putting in new fuel lines.
Old 04-25-2006, 09:44 AM
