Replacing CV joint on 79SC
Anybody have any idea how much will cost to replace rear CV joints on 79SC? Was told by mechanic that I need to replace right rear. Also, was told must replace both sides eventhought the left is fine. Any response is greatly appreciate. Thanks.
Arsenty
Old 04-25-2006, 09:14 AM
IROC's Avatar
You really only need to replace the defective joint, IMO. They don't need to be replaced in sets or anything.
How much would it cost? Depends on his labor rate, I would assume. These are pretty easy to replace and are pretty cheap. Our host sells the CV joint itself for around $75. Add $20 or so for a boot, grease, etc. and you're looking at $100 in parts. If he charges more than $200, I'd be shocked.
Then again, I'd do this myself...
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 04-25-2006, 09:51 AM
Thanks Mike.
I'll try to replace CV joints myself. I have a feeling I'll get charged more than $200. I agree that I need to change only the bad one. I seen some good posting on this forum how to replace the CV joints. Anything else I should be replacing while replacing the CV joints?
Arsenty
Old 04-25-2006, 11:43 AM
Paper Member
Get new bolts too......
Enemy of the State
Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it.
Old 04-25-2006, 12:00 PM
coloradoporsche's Avatar
There's a HUGE thread on this if you do a search. Way more than you ever wanted to know about CV joints...down to an analysis of metallurgy, etc.
IMHO, on a 79 like ours, all you need to do is replace the joints which can be bought for ~$90 each from Pelican. Inspect the hardware for damage and replace if needed. Inspection for CV joint bolt (OK, "cap head screw") tightness should be done after driving 100 miles, and as part of your pre-track inspection every time.
Sheena is a punk rocker
Suzy Is A Headbanger
Heidi Is A Headcase
Judy Is A Punk
The Ramones' earliest titles included 'I Don't Wanna Walk Around with You,' 'I Don't Wanna Go Down to the Basement,' and 'I Don't Wanna Get Involved with You.' Dee Dee later said, "We didn't write a positive song until 'Now I Wanna Sniff Some Glue'."
Old 04-25-2006, 12:14 PM
IROC's Avatar
I bought the bolts locally for about 40 cents each. They're nothing special. It is nice to replace them - "while you're in there".
Mike
Mike
1976 Euro 911
Old 04-25-2006, 12:18 PM
"They're nothing special"
Actually they are; they need to be strength class 12.9. Metric socket head cap screws (bolts) are also made in lesser strength grades (10.9) which are not adequate for this application. CV joint screws should have a 12.9 mark on the head.
If the CV joint screws are in good condition (not corroded and the wrenching features unmarred) then the bolts may be reused. Always replace the Schnorr lockwashers.
Old 04-25-2006, 12:44 PM
If you get in there and find that you need to replace both joints you may find it easier to simply buy the entire axle assembly versus replacing individual CV's. The new assembly is a simple bolt on and if you consider the two joints are $75.00 each and the boot kit cost, the special pliers for the clamps and the mess of dealing with the old CV's you are beginning to approach the $250.00 or so it costs for new complete end-to-end CV axles. Just a thought for consideration. I think the CV joint also is a press-off and press-on job meaning you need access to a shop press and there are lots of ways to screw the joint up when using the press. Someone correct me if I'm wrong here.
I chose to replace the entire assembly.
Old 04-25-2006, 02:27 PM
IROC's Avatar
What I should have said was that 12.9 socket head cap screws are very common. They're nothing "exotic". I bought them at the local fastener emporium for about 40 cents each.
Mike
Mike
1976 Euro 911
Old 04-25-2006, 02:59 PM
Semper drive!
rcecale's Avatar
Several of the PPBBS superstars have made this thread the be-all to end-all in CV Joint Information
Click here.
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
I was thinking the same to change the whole axle. It might be easier and cheaper in a long run.
Randy,
I read that thread and I am affraid I'll run into some problem whereI would end up changing the whole axle.
Old 04-25-2006, 04:30 PM
Licensed User
Shuie's Avatar
The next time you have a couple of hours to spare, click on Randy's link.
I went with new halfshaft assemblies as well. Its not a cheap project. Its not terribly difficult either. It is a dirty job and it is very important that everything is done properly (read the linked thread above).
Buy new hardware. Thats the cheap part of this project. 24 bolts, 24 lock washers, 4 gaskets, and the 4 half-moon shapped spacers is probably less than $50. The halfshaft assemblies are $200-$300 each depending on who you get them from.
Check with your local Autozone type chain for core exchanges on the entire assemblies. You'll be surprised at what you can sometimes find for literally 1/2 of what everyone is selling it for. It didnt work for me on the CVs, but you never know.
gratuitous new CV halfshaft assembly pic
Old 04-25-2006, 06:45 PM
