Where can I get this fitting
Im trying to look for a fuel rail adaptor fitting so I can run my fuel pressure guage. I've bought a fuel pressure guage, but none of the fittings work. Can someone guide me to a site that would have the correct fitting adaptor.
I think the stock size is a 14mm x 1.5.
1986 944 Turbo - Guards Red
Old 04-26-2006, 06:10 PM
RETIRED
Joe Bob's Avatar
Summit or Pegasus Racing, McMaster or BAT Inc. All are on the net.
2012 ML350 3.0 Turbo Diesel
Old 04-26-2006, 06:11 PM
Not having too much luck. Im finding fittings just not the one I need.
Can someone verify the fuel rail fitting size on an 86?
Old 04-26-2006, 06:53 PM
HarryD's Avatar
I would try one of the larger industrial hydraulic shops in the area. Since you are in the oil patch, there should be some very good ones in the area.
Most have a wide assortment of fittings and you should find one that works. If not, they may be able to braze something for you.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 04-26-2006, 08:01 PM
DW SD's Avatar
Just like Mike offered, but a little more specific.
Go to www.batinc.net, place a call and explain what you are trying to do. He'll help. You might make a T from AN fittings, but they have the adaptors you'll need.
Good luck,
Doug
1971 RSR - interpretation
Old 04-26-2006, 10:24 PM
