dan79brooklyn's Avatar
78-80SC Who is using 87 Octane
The 78, 79 (and 80?) SC's are 8.5/1 compression.
The previous owner/dealer said 87 octane is sufficient.
However I have only ever used 89 in my '79.
But rising gas costs and curiosity got me thinking maybe 89 really isn't necessary.
I don't have the factory manual, anyone know what Porsche reccomended?
What are your thoughts?
Current Drivers - 2006 BMW 1 Series & MB E320 Wagon
(new addition 1998 Mazda Roadster)
EX - 1993 Porsche 911 Carrera 2
EX - 1979 Porsche 911SC TARGA
EX - 1976 BMW 2002
Old 04-27-2006, 12:37 PM
SilverPoly's Avatar
I've heard it said that 89 octane is the least used fuel at the pumps and thus sits there longer. I'd go with 87.
I run 91 since my rebuilt engine is using euro p&c's.
Old 04-27-2006, 12:40 PM
MAGA
Tim Hancock's Avatar
I run 87 octane in my '79 SC and that is all that is required.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 04-27-2006, 12:47 PM
vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
I've used 87 in my 911 and cannot tell the difference from the 93 I normally run - and with the price of gas I suspect I will be using it more often!
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Just FYI...gasoline only comes in two octanes to the station: 87 and 93. 89 octane is just a mixture of the two drawing from the 87 and 93 octane tanks in the correct proportions.
Old 04-27-2006, 01:16 PM
emcdan's Avatar
I can't tell any difference with higher octanes but mine runs better with 87 Chevron (tecron) than the others.
Deutsche Fahrzeuge
78' 911SC
03' 325I BMW
03' KTM 450sx
05' S2000 (daughters)
Old 04-27-2006, 01:30 PM
I'm with Bill
Rick V's Avatar
If I run 87 in mine (82) I get alot of predetionation under hard throttle. 89 is a little better but still not too quiet. We don't have 91 where I live so I feed my SC93. With $.10 diff. per grade it only costs me $4.00 exrta to use the good stuff if I let it get that low. Just go with the higher grade and drive hard&happy
Old 04-27-2006, 03:17 PM
khamul02's Avatar
Just noticed you have an 82sc. Didn't the compression rate go up for the 81SC? Not 100% sure. but if it did that would explain the "predetionation under hard throttle".
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 04-27-2006, 04:13 PM
oneblueyedog's Avatar
87 for me.
78SC coupe, Silver Metallic
Old 04-27-2006, 06:37 PM
S2GART's Avatar
The owner's manual for my '83 says the min. oct to use is 87. Here in CT, that is averaging $3.05 a gallon right now. Also, here in CT "super unleaded" is 93 octane, whereas some parts of the country the highest you can get is 91.
The "collection"
1983 911 SC Targa (1 of 1430 imported)
1994 MB E320 Coupe (1 of 825 imported)
1992 MB 190E 2.6
2004 Volvo V70 2.5 Turbo (1 of a bazillion imported)
Old 04-27-2006, 06:46 PM
khamul02's Avatar
Must be the Carreras that got the higher compression ratio. Well, those guys have plenty of money so that higher octane should be a problem.
Tom Hutchinson
Old 04-27-2006, 07:16 PM
Zombie
This is news to me. I had a 78 and a 82 sc and both would knock badly with anything lower than 90 although it mostly happened when in 5th gear at lower speeds.
Old 04-27-2006, 07:28 PM
Right on..so I will be running 87 from here on.
Let you know if any issues...
The Venezuelan gas is good : CITGO?
Which Co. should I give my $$ to?
EX - 1976 BMW 2002
khamul02's Avatar
All I know is my owners manual says 87 so that is what I use with no issues.
Tom Hutchinson
Old 04-27-2006, 08:00 PM
kumma's Avatar
use the lowest octane rating that doesnt cause pinging and definitly not detonation. anything else is just money out the exhaust pipe.
Old 04-27-2006, 08:31 PM
Even my 86 3.2 Carrera runs fine on 87.
Old 04-29-2006, 06:50 PM
