slide valve MFI runnability ??
Hi,
I'm planning to build a 2.7 RS spec twin plug to run in my 72 weekend driver. High butterfly are to expensive, so what about slide valve ?? Any experience with oem or aftermarket system ?
Does someone try to reproduce exact copy of the original ?
Thanks !
65 coupe, Dolphin gray #1506
70S coupe, Blood orange #1436
R Gruppe #647 ; S Registry #1666
Old 05-09-2006, 04:47 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
As stated many times...slide valves are prone to dirt.
If they stick open...your engine is toast.
I have been working on a set (from scratch) for myself.
As of this time, I have not solved the sticking problem.
I have installed so many sealed ball bearings for the slide to run on that my supplier is sending me valentine cards!...LOL
The Problem is in the area of the opening to the intake bore.
The charge will revert or back up into the slide area.
I have now redesigned the lower tube (to the intake) with an anti-reversion tube to try to keep the reverse pulses from hitting the slide.
More tests to follow.
Bob
Bob Hutson
Old 05-09-2006, 06:50 AM
randywebb's Avatar
that's what I thought also
but...
do a search - somone knowledable said the slide valves would do just fine - maybe here or on Rennlist... maybe it was Steve Wiener
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 05-09-2006, 12:16 PM
