spark plug wire size? replacement for OEM
I have a 1983- 911SC with stock ignition wires, not sure how old they are but was thinking of replacing the wire and reuseing the ends. So what size wire ( 7mm ? ) do you guys buy and where do you buy it? I know the Beru spark plug ends are the screw type? as I unscrewed one and it had a little screw stud inside. Are the distributor ends the same with the screw stud? Or are they a crimp type end? Any "tricks" or is this a simple deal?
