Bird. It's the word...
Fishcop's Avatar
Electronic Anti Rust Devices?
I regularly see advertisements for small electronic devices that are installed into cars to prevent rust. The theory is that a small negative (or positive?) charge is is permanently emmitted through the chassis and metal parts of the car which stops the rust from generating.
I've spoke to a few mates that are hard-core beach fishermen (we've got miles of beach designated as highway for 4x4 cars ) and they swear by the devices. But I've noted that their trucks are quite modern and galvansied, so I don't think it's a fair comparison with older cars.
Anyone using this kind of device? Anyone have some opinions? Is it voodoo?
Cheers
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 05-14-2006, 06:23 PM
Monkey Wrench
Spede's Avatar
They seem to be really popular in Hawaii. I'm not sure if they really work or not but it really didn't help my aunt's 1995 Caravan there though.
Old 05-14-2006, 06:32 PM
Its not Voodo, its call Cathodic Protection Engineering. The basic principle is simple, a metal dissolution is reduced through the application of a cathodic current. Cathodic protection work best to coated structures, with the coating providing the primary form of corrosion protection. Search web under CP..
Old 05-15-2006, 12:58 AM
I have a friend who lives in Rochester, NY (aka "Salt City") who has used them on two Ford Taurus cars that he previously owned and his current car, a Toyota Lexus. He is totally sold on them.
Old 05-15-2006, 07:18 AM
Original Owner
tsuter's Avatar
I wear magnets in my shoes.....
tsuter
78 911SC Turbo Targa
Thaaaats Right!!
Old 05-15-2006, 07:27 AM
Super Moderator
cstreit's Avatar
Tehnology like this has been used for a long time on ships. A small electric current is passed through the sacrificial devices on the underside of the ship...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 05-15-2006, 07:55 AM
Information Junky
island911's Avatar
I thought about this once, but in terms of positive or negative ground (the Brit's had some cars with pos-ground) . . .which is better, for keeping the metal happy? That is, your battery is a reservoir of electrons . ..but which lead (to be grounded) will provide the easiest flow sacrificial electrons?
But then I thought, eh, I'll just buy an SC.
Ships wear "zincs" (big chuncks of zinc) which will provide sacrificial electrons to the steel.
My latest concern, however, has been that for the fan, and other magnesium parts. Those parts are like the zincs on those ships (electrolyticaly speaking).
Old 05-15-2006, 08:03 AM
The book I puchased titled "How to paint your car" talks about this item. I just bought a 74 (I think is not galvanized) will be wearing one of these units soon.
Old 05-15-2006, 08:52 AM
charlesbahn's Avatar
It works well, if your car is submerged in salt water.
"Igneous Aquam et Laudi semper"
Carl Muckley
Old 05-15-2006, 09:46 AM
SC-targa's Avatar
As charlesbahn said, I can't imagine it does anything unless the car is submerged. You need an electrolyte for the charge to pass through and you can't pinpoint it on a dry car. I've used sacrificial anodes (magnesium) to protect aluminum process tanks before with good results, but they were submerged.
Regards,
Jerry Kroeger
82 911SC Targa
(05 Boxster S ) gone, but not forgotten
87 Suzuki GSXR-1100
1953 MG TD Mk II
Old 05-15-2006, 12:30 PM
Wider is Better
wholberg's Avatar
Years ago I saw kits sold with a 3-5 lb zinc block that bolted to the inside of the body and was wired accordingly. The caveat to using them is that every body panel needs to be electrically continuous, or a piece of zinc needs to be on every panel. I saw one on an old truck years ago and the owner had actually spot welded connections between every body panel. In another application I saw the owner had connected every body panel with 10 ga. wire.
The use of a sacrificial zinc anode is not new, and it is a lot better than nothing on a non-galvanized car. I don't think it will substitute for modern rust protection, but in the Northeast, it will keep you from haveing to replace a non-galvanized body every 2-3 years.
Here is a commercial site I pulled up on Google that sells the zinc anode kits.
http://www.ruststoponline.com/ruststop-kit.html
Wider is Better
Old 05-15-2006, 03:58 PM
Fishcop's Avatar
Thanks guys.
I'm well versed on sacrificial anodes on boats, and as you rightly point out, that occurs in a conductive bath (seawater).
I just didn't understand how a current being passed through the car helped prevent rust. I guess anything that helps even slightly is better than nothing. I was hoping someone might have a couple of cars to compare - one with and one without?
John Forcier
Old 05-15-2006, 04:40 PM
