I am a relative beginner when it comes to CIS. Car has been running great lately. But I just noticed the idle was a little low say around 800 or slightly below when engine is warm. It seems
the idle would float a little too as it fluctuates from 800 to 900. I tried to screw in the idle screw about a half turn or so and it didn't seem to do anything. Could this be a vacuum leak? Anyone have any ideas? Thanks
'75 911S Silver Anniversary #164(Formerly JTO's) Rebuilt 2.7 with full ARP, 9:1 CR. SSI, GHL, ER polybronze bushings, finned oil lines. Lowered and corner balanced. CIS retired, now PMOs! '65 912 slate gray sunroof (driving project) |
A vacuum leak would normally cause a higher idle. Trying unscrewing (counterclockwise) the screw to allow more air in.
David |
It's a balance thing, if you adjust the idle bypass you need to be ready to adjust the mixture as well. But yea, start by checking for leaks of course.
Injector O-rings Injector bungs Brake booster connection Air box halfs Cracks in the air boot lose clamps on the oil breather hoses Intake runner boots Intake runner gaskets
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Designer King
It's also possible your mixture is a tiny bit rich. Try the CCW turn of the idle screw and let us know what happens.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
So, let me get this straight. CCW increases idle and CW decreases? I turned the thing a 3/4 turn CW yesterday.
ael911,
The screw blocks the passage that allows air in for idle. By screwing it in (CW), you are blocking more of the air passage. By screwing it out (CCW) you are opening up the air passage. Also check your points and timing to be sure nothing is changing there.
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL |
Thanks guys, I will go home and try CCW the idle screw
Designer King
BTW I just realized my comment may be misleading. The idle screw doesn't affect mixture. That is done by the mixture screw on the fuel distibutor/mixture control unit. My suggestion was to try raising the idle first and see what happens. If that doesn't do it, then get back to us.
Okay, I will try the idle screw first to see what happens. The issue is really subtle as the rpms only fluctuates a little bit. But enough to where I notice it. I also notice the rpm will dip down to about 600 when I spin down and come to a stop without load. The rpms will then jump back to 800 or so and idle. The engine is warm and the alternator light does not come like close to a stall.
After putting in the kit plan on redo the timing, adjusting your idle speed and playing with your fuel/air mixture (mine is too rich right now) to get it right.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
Designer King
Scott R:
That's not what's supposed to happen. That air is supposed to be bypassing the throttle, not be added to the mix. What change in CO do you get for how much of a turn of the screw? We're talking the big flat one here, right?
I run well at .8 but I like the power around 2.5 so I was going to bump it up.
The car already has a Petronix Ignitor...
Troy
Troy Past: 1975 911S Silver Anniversary-rebuilt and sublime. Past: 1988 Carrera-backdated with a 3.6 and all the goodies. Present: 2011 GMC 2500HD with the 6.0 & 4x4!, 2004 Toyota Sequoia (wife's) |
Souk at MotoMotions went through the logic of CIS idle and mixture in great detail in the following thread. I can't say that I understand it all, but it comes from a great source:
CIS Idle Speed and Mixture Setting Without an Analyzer
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL Last edited by Walter_Middie; 05-17-2006 at 10:30 AM.. |
Hi guys, I turned the idle CCW a little bit this morning. Brought the idle to about 900. She seemed to run smooth. Deceleration valve seemed to be working better as the deceleration slowed down when the rpms came down to 1500 and slowly settled back to 900.
Troy, thanks for the post. I knew you'd be around.
Yeah, I'm skulking around, keeping tabs on the old girl and her new owner.
.Troy
