Kevin Stewart's Avatar
WoW, Wevo shifter this just cant be
Just finished putting a wevo shifter in my 82, wow, this is a serious shifter, after using the the old slop shifter and going to this it just cant be that good but it is. i still have the junk motor mounts in and im not sure if the shifter is quit adjusted right yet. I would say its at least 80-90 percent better. you could not have convinced me before i put it in. the throw is real short not a lot of side to side movement just feels real precise.
question does the reverse pin suppsed to click every time going from 4th to 5. The instructions say that it is supposed to lightly touch.
anyway ill get pictures later. i cant make up my mind to use the consel with no boots or use the boots and hide everything.
before i forget, the handle felt kinda low to the ground feels like it could be taller, (maybe this is bacause i have been driving my dually 5 speed lately.
Great product, this was low on my list before but i think it should be one of the first updates now, not worrying so much about what gear your in is worth the cash, Kevin
Old 05-19-2006, 10:22 AM
Insert Tag Line HERE.....
rattlsnak's Avatar
After years of shifting various 'sloppy' 911s, even with short shifts, i couldnt believe the difference the WEVO made either!
Marc
Old 05-19-2006, 11:12 AM
rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
Was it difficult to install?
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 05-19-2006, 11:19 AM
lateapex911's Avatar
Wevo makes TONS of 915 stuff..which mod did you do, exactly? Anything on the couplers or in the trans itself?
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 05-19-2006, 11:38 AM
chrisp's Avatar
Mine clicks going into reverse.
'83 SC
Old 05-19-2006, 11:39 AM
Administrator
Jack Olsen's Avatar
Mine makes a light click going into fifth. It's a great feedback mechanism to let you know that you've upshifted correctly, and aren't about to blow your motor with an inadvertant 4th-to-3rd mis-shift.
Old 05-19-2006, 11:48 AM
Me like track days
Craig 930 RS's Avatar
Getcher WEVO coupler to make it complete........
BTDT on my old 3.6 SC
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 05-19-2006, 12:13 PM
I just did the shifter, pretty easy to install, had to play with a bit so it will go in reverse right, the instructions say that it has to barely touck the the push in lock which is what make the shifter click,
this was the only upgrade I have done so far. I have two wevo motor mounts I think ill install at the tranny. (my motor and tranny mounts are lets just say junk) I do have a 3.6 so I was worried about the dreaded shift miss. Wevo made me a believer in their products.
The shifting is so good that when i first drove the car i was still concentrating on shifting. Two hours later and 30-40 miles and i have relaxed with it and it just gets smoother. What the heck was Porsche thinking when they put that VW shifter in our cars.
The 3.6 made run and feel like a modern Porsche, the wevo shifter has made it shift like one. Some of you may not know that i have pretty much just stuffed the car in the corner for like 4 years. even after the 3.6 i was just not interested. this spring it was my goal to sell it or drive it. I beleive the shifter has made that much of an improvemnet that i like driving it again. I have the car for 6 years the first two were great then it was just no more love. I may be getting the feel back. heres a picture of the car, Kevin
Old 05-19-2006, 12:43 PM
Originally posted by Kevin Stewart
....... I beleive the shifter has made that much of an improvemnet that i like driving it again. I have the car for 6 years the first two were great then it was just no more love. I may be getting the feel back. heres a picture of the car, Kevin
I gotta think I could feel the "love" for driving that...even with a loose shifter, LOL...
Old 05-19-2006, 12:46 PM
19 years and 17k posts...
azasadny's Avatar
What a gorgeous car!!!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 05-19-2006, 01:42 PM
DavidI's Avatar
Great looking car Kevin.
99 996 C4
11 Panamera 4S
83 SC Targa converted to a 964 cab (sold)
67 912 (sold)
58 Karmann Ghia choptop (traded for the 912)
Old 05-19-2006, 04:10 PM
Thanks for the compliments, like i said it just wasnt fun to drive before, its better, Kevin
Old 05-19-2006, 08:34 PM
