Help With CIS Idle Adjustment
Could anyone out there post a picture/graphics of the CIS system on a 3.0.
High lighting where the Idle adjuster is please.
I am currently having difficulty posting pictures.
1975 911 3.0 Carrera (964 Lookalike Weekender)
1975 911 2.7 (Project)
1979 Ford RS2000
1980 Mini 1275GT
1998 BMW 320i (Daily driver/Reliable Work Horse)
Old 05-22-2006, 12:13 PM
bigchillcar's Avatar
no pic, but hard to miss once you know where to look. driver's side of engine bay..it's a large silver screw, about as wide as a dime with a flat head insert..also a spring on the shaft. clockwise to reduce, counter to increase iirc..anyway, you'll figure that out easily enough. this idle screw faces out towards the driver's side of the car. also, you gotta make sure that the car is right at operating temperature to set it correctly (180 degrees), otherwise the cold idle speed will be incorrect. i'm sure someone will post a pic if you don't find it..it's in pretty plain view the left of the airbox..
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 05-22-2006, 12:20 PM
Thanks Ryan, yeah I found it. I suspected that was it, but I wanted to be certain.
1979 Ford RS2000
1980 Mini 1275GT
Old 05-22-2006, 12:46 PM
cool beans..
Old 05-22-2006, 12:51 PM
Banned
diabolos88's Avatar
Turning it clockwise will fatten the mixture, turning it counter will lean it out. When trying to adjust the mixture you will insert your T handle in the allen hole then push down and slightly turn until you can feel the allen engage with the screw in the assembly. You don't wan to push too hard as this will cause the engine to die out. When you make your adjustments do so with little turns or you will end up in no mans land. Lastly CO adjustments should be done with a proper CO meter. By ear regardless of the best of them is not proper and will not yield maximum results. Your CO% target is 3.4% for best high performance. To pass smog, it should be set to just less than 1%.
Old 05-22-2006, 08:59 PM
ianc's Avatar
Diabolos, you are confusing the idle adjustment with the mixture adjustment,
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 05-22-2006, 11:00 PM
Banned
diabolos88's Avatar
yep, I am! oops my mistake
Old 05-22-2006, 11:07 PM
Go straight in from the top verticaly, not at the angle shown (just pointing to it).
You will need a 4" long 3mm allen wrench. The hole is just a hole, the adjustment screw is past the hole down there.
Old 05-23-2006, 07:56 AM
Designer King
Paulporsche's Avatar
kach221,
Remember, that is for mixture adjustment, which does affect idle speed. But the idle speed adjustment screw is the one described by ryan.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 05-23-2006, 08:04 AM
Originally posted by Paulporsche
kach221,
I was following what "diabolos88" said, sorry about that.
I need to read what my Hayne's book says about this again - my mind is still on the topic.
Old 05-23-2006, 10:42 AM
jmeany's Avatar
Send a message via Yahoo to jmeany
HELP!! With CIS Mixture adjustment
My son was tring to help. He took the 3MM wrench and turned it a "whole bunch of times" Now the car won't run. He used a pair of pliers to turn it. Now it is seized. What do I need to do to fix this? Does the engine need to come out? Do I need to remove the distributor and air box assy?
I am soo pissed...
Old 06-13-2006, 08:20 PM
ianc's Avatar
jmeany,
Tough times. Are you unable to turn the screw with the 3 mm wrench anymore? Which way did he turn it, and can you turn it in the opposite direction?
ianc
Old 06-13-2006, 08:35 PM
jmeany's Avatar
That is the problem he turned it counter clock wise & does not remember how many times. we did not feel any clicks I have tried everything I think.
Old 06-13-2006, 08:48 PM
he may have leaned it out completely. sometimes they don't make clicking sounds, don't be overly concerned about that..however, you need to try to get it back into the slot and turn it clockwise, if possible. try to keep track of how many complete turns you do based upon his estimate. at this point, i'd just try and get 'in the ballpark' enough to get it running. mixture cannot be set accurately without a co gas analyzer. it's gonna be worth it to take it now to a shop equipped with one and have them 'baseline' your proper mixture setting, otherwise you're really shooting in the dark now. it shouldn't be too expensive and really needs to be done. some people claim success setting mixture by duty cycle, but they're pretty sharp at doing this. if you can't get it to turn, the fuel distributor may require removal at most, but certainly not the entire motor. what year and model 911? don't disown the son just yet.. do let him know that 'less is more' when it comes to adjusting mixture..an eighth or quarter turn can be significant..
ryan
Old 06-13-2006, 11:21 PM
jmeany's Avatar
The 3mm hex screw is seized. I can't turn it right or left at all. I can't see what is going on under there because of my eyesight. I am thinking of removing the fuel distributer so that I can see it better and why the screw is bound up. How dificult is that procedure and is there a technical bulliten I can read about how to fix this?
You folks are wonderful. I am thankful that you take the time to help me wuith this issue.
-john meany
PS it is a 1981 911SC 3.0L
Old 06-14-2006, 05:58 PM
ianc's Avatar
Well, if your young son was able to get it where it is with pliers, maybe you can try the same treatment (gently) to turn it clockwise again. Worth a try, but be careful...
ianc
Old 06-14-2006, 06:16 PM
jmeany's Avatar
Your right and he did free it up just a few minutes ago... Now I am keping my fimngers crossed that we can get it close enuf to go to get the gas analyzer test and set up done.
Old 06-14-2006, 07:19 PM
ianc's Avatar
What? You're still letting him work on the car?
ianc
Old 06-14-2006, 07:59 PM
Somewhere in the Midwest
MotoSook's Avatar
This must be your son's thread:
Ballpark adjustment of CIS idle mix
Old 06-14-2006, 08:19 PM
jmeany..glad to hear it. i'm sure you can get it running well enough to get it to a shop with a gas analyzer now. glad you didn't have to pull the fuel distributor, etc. spend the little money now..it makes sense to get it baselined..very worth the trouble and expense.
ryan
Old 06-15-2006, 01:13 AM
