m_wuebben's Avatar
Talking First engine drop
Dropped for trans rebuild. no injuries, minor bendage. Here is my magnet art and a tooth. The obligatory engine bay photos featuring my "help". I will be asking the traditional "should I change this" questions. Cheers, Mike
1981 911 SC Black / Black & Tan sunroof coupe.
Run like the wind...straining the limits of machine and man... (Peart)
Old 05-27-2006, 07:49 PM
SP2 SP2 is offline
SP2's Avatar
Nice job! But good god are you saying you lost a tooth in the process?
James
1969 911E Slate Grey
1981 911SC Wine Red
1997 911C4S Ocean Blue
Old 05-27-2006, 09:45 PM
Jeff Alton's Avatar
Way to go!! But shouldn't those helpers be covered in grease??
Cheers
www.turn3autosport.com
Nice work, where are you located in MI?
Michael
Sans Porsche...for now
2009 Mazdaspeed 3 Grand Touring daily driver / DS autocross toy
2010 Subaru Forester X Limited - wife's daily driver
Old 05-27-2006, 09:48 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Cheers
or at least a shirt ....
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 05-27-2006, 10:44 PM
m_wuebben's Avatar
Yeah, ischmitz, but they were more of an obstruction look out team for the drop than actual 'help'. The rest was a one man show.
vanwyk4257, I am in Monroe, just north of Toledo, Ohio.
Well, time to break into the case, more later. Cheers, Mike
Old 05-28-2006, 04:04 AM
rallyracer's Avatar
dang, you guys beat me! i should have mine out in a couple of hours for a tranny rebuild also, if i can get the return fuel line loose...
good luck!
david
-born and raised in Toledo, OH. now in Houston, TX. i've forgotten what rust looks like on a car.
1983 911SC-Sold!
Old 05-28-2006, 07:40 AM
Blanco's Avatar
Yup... did mine as well not too long ago.
post pics as you get damage assesment.
1982 Porsche 911SC Coupe - Factory Short Shift |7:31 R&P in AL case | Toyo RA1 Tires | Corbeau TRS seats | M&K 2 in 2 out muffler
Old 05-28-2006, 09:36 AM
m_wuebben's Avatar
Got the end cover off. Found six more dog teeth. Not much more progress today for want of a 41mm or 1-7/16 socket. Tomorrow the rest comes out, start cleaning and waiting for parts. Cheers, Mike
Old 05-28-2006, 06:52 PM
m_wuebben's Avatar
Trans is out and apart. Cleaning and waiting for parts.
Old 05-30-2006, 08:36 PM
SP2 SP2 is offline
SP2's Avatar
So you are rebuilding your transmission. I have never done this but would like to. Could you describe what you are doing, like in a DIY manual type of way? It seems like you have done this before? Maybe you can start a new thread on this.
What part is it with the teeth gone? And what symptom would it produce (did it produce?) Very interesting photos to newbies like me!
Thanks,
James
1981 911SC Wine Red
Old 05-30-2006, 09:00 PM
m_wuebben's Avatar
I have followed a couple of people on their rebuilds here, that is all. There are many threads that I have copied and read. Try a search for user name 'rcecale' and subject 'Can't Shift Into First', also 'While the tranny's out' by ohecht. The article 915 Tranny Rebuild has links to more help. I have been lurking about here for a couple of years, but I am far from an expert. If you ask for help, you will get it. I will help you with what I can. I have close to 100 pics of what I have done so far. It is not that difficult at all. Cheers, Mike
Old 05-30-2006, 10:56 PM
m_wuebben's Avatar
James, the part with the teeth gone is the; '915 Synchro Hub / Dog Teeth (sold per each), Symmetrical 1st Gear 911 (1972-76), 2nd Gear 911 (1972-86)' for second gear. The other with the teeth ground off is; '915 Synchro Hub, Asymmetrical 1st, 911 (1977-86) Brand: Getrag', both purchased from our host. The reason I tore into the trans in the first place is because I found teeth on a gear oil change and I had trouble shifting into first.
Old 05-30-2006, 11:02 PM
SP2 SP2 is offline
SP2's Avatar
Cool. Any special tools I will need? I saw you needed a 41mm socket. Were you serious? 22mm is my largest, but I will get what I need to do the job. It is good to hear that it is not that hard. When I pull my engine this summer, tranny is on the list of to do.
Thanks,
James
1981 911SC Wine Red
Old 05-30-2006, 11:52 PM
m_wuebben's Avatar
I am not an expert, but as is told here, you need no special tools. A good high lift jack and jack stands, 1-1/16 & 1-7/16 socket, somehow a way to remove the input shaft nut, and torque it back on (read the threads above). So far, the coming apart and cleaning has not been hard, but I still have to go back together. Cheers, Mike.
Old 05-31-2006, 06:24 AM
19 years and 17k posts...
azasadny's Avatar
m_wuebben,
I'm doing my first engine/tranny drop to replace my engine with another. What did you do to get the tranny loose? What is the secret for removing the clutch cable and transaxle bolts? I'm in Wyandotte, MI. Thanks!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 06-10-2006, 07:44 PM
m_wuebben's Avatar
Art- once the four nuts were off, I just wiggled the trans up and down several times (the engine was sitting on a furniture cart) and I saw the parting line start to separate. On the clutch cable, I pryed the spring off and the cable releases from the spring. My transaxle bolts were, I believe, #8 capscrews. Keep in mind that I am working on a 1981 SC, so some others here may be able to help you more. Do you need some help? I may be able to come lend a hand, and moral support, but very little expertise.
Old 06-11-2006, 05:45 AM
azasadny's Avatar
m_wuebben,
Thanks! I got one axle freed up, but I'm still fighting with the other. I'm going to try and get the clutch cable disconnected this wek, then hit it again ealry next Saturday and try and drop the engine/tranny together then.
Art Zasadny
www.ford.com
Old 06-11-2006, 06:32 PM
m_wuebben's Avatar
Art - I read about the pin in the other psot. I did not have that on my arm. Are you just going to leave the arm on? Cheers, Mike
Old 06-12-2006, 02:07 PM
Porsche Junky
mede8er's Avatar
Ah...the good old days.....
But 25 years later there's still something exciting about taking this stuff apart and putting it back together....as long as it works when you're done, of course......
1986 930 RUF equipped
Old 06-12-2006, 03:10 PM
