eddiehotrod's Avatar
Hi-torque starter mechanism different from standard?
Hi all, I recently bought a hi-torque starter, but I've noticed that the gear mechanism is the type that extends on rotation by about an inch - but the standard starter that I've just removed doesn't do that. It's fixed. Have I bought the wrong thing? Thanks.
Old 06-04-2006, 02:35 PM
rnln's Avatar
umm.. I don't know P car starter but I thought all starter need to extend on rotation. If it's fixed, doe that mean it stay on the gear and rotate all the time when the engine is running?
Fat butt 911, 1987
Old 06-04-2006, 02:40 PM
rnln's Avatar
Why do you have to replace the starter? is your old starter bad? I have seen bad starter that doesn't do anything when hook up and I also seen bad starter rotate without extending. This is why the gear doesn't get engage and car doesn't start.
Fat butt 911, 1987
Old 06-04-2006, 02:41 PM
randywebb's Avatar
The solenoid extends the starter shaft so its gears will mesh with the flywheel's ring gears.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 06-04-2006, 03:09 PM
Ok, so it looks like the old starter's shaft is supposed to extend but doesn't, which explains why it wouldn't start my car anymore. Thanks for your replies.
Old 06-04-2006, 03:23 PM
Sounds like your old starter rotates but doesn't engage. That right?
Interested in exploring some? Since your car has a working starter, you could perform an autopsy and see why the gear doesn't extend. It might be mechanical (e.g. broken lever arm) or electrical (e.g. open or shorted electrical circuit). Either is fixable to create a spare. If you lose interest after tearing it apart, you have numerous paper weights. :-)
Sherwood
Old 06-04-2006, 06:27 PM
Banned
hows the hi-torque starter working for you? I was just looking at one, I need a starter.
Old 06-04-2006, 07:04 PM
Thanks Sherwood, I'll give the autopsy a try, although once the car is back up and running I suspect the old starter will just sit on the shelf gathering dust.....
Dynevahn - I haven't fitted it yet, but when it's in I'll let you know what I think.
Old 06-04-2006, 11:06 PM
Bill is Dead.
cashflyer's Avatar
One of the better decisions I have made was to switch to the lighter, high-torque starter.
Old 06-05-2006, 06:23 AM
It's fitted and working and I love it. The noise is like a compressed-air driven sewing machine, but it's got a sort of race car noise that appeals to me. While I was in there I fitted a new negative battery cable and an extra earth cable from the starter to the gearbox. So that should fix my latest run of no-start issues......
Old 06-07-2006, 02:21 PM
mjw mjw is offline
I replaced my 33 year old stock starter with the lighter weight high torque unit a couple of months ago; it works great.
Marty
'73 911T 2.4 MFI
Old 06-07-2006, 02:53 PM
too much torque??
I have a Hi-torque starter,love the sound, works great.
A friend recently suggested that it has TOO much torque for our old cars. Mine is in a 1970.
It spins too fast, too hard. and it will cause damage down the line. I believe it was the pinion that gets damaged.
Anyone heard of this??
Ray Crawford
1972 911 S Targa
1973 E Flairs n Chairs
Old 06-07-2006, 03:06 PM
Re: too much torque??
heard about this in days of old Chevy days. It was the flywheel ring gear that would get chipped.
I've been using a high torque started, Tilton, for years with no damage.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-07-2006, 03:16 PM
