9dreizig's Avatar
Send a message via AIM to 9dreizig
EFI - why has someone not done this?
I've been thinking( always dangerous). Why has someone not taken a mass produced EFI/engine management system say out of a GM six banger say a Grand Prix or some other car. Re-mapped the CPU and applied it to a 911 ? Seems like you could pick up the whole system from a junk yard for a song. Might have to change a few parts like injectors but you'd have a hardened proven system. Am I way off on my thinking ?
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 06-05-2006, 03:58 PM
bigchillcar's Avatar
don't know about converting those, but there are several variants already out there...pelican member, tbitz, for one has his available. do a search under 'tbitz' and 'efi' and you'll see..if you're not already familiar..
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 06-05-2006, 04:06 PM
9dreizig's Avatar
oh ok thanks, it just seems to make more sense than a "heathkit" version from an electronics standpoint
"Todd"
Old 06-05-2006, 04:09 PM
The reason I wouldn't do that is cause the ecu isn't progamable like progamable aftermarket efi.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 06-05-2006, 04:24 PM
klaucke's Avatar
People on the forum have done that before, but it turns out to be a lot of work in the details. After all the work, you're probably better off w/ an off the shelf after market system (T-Bitz, Mega-Squirt, Motec, Tec3, etc) that can be optimized for performance if you're going to go through the trouble.
Old 06-05-2006, 05:34 PM
Just off the top of my head I'd think that the sensors involved with a water cooled car would be different from an air cooled 911. This alone would make reprogramming a less than straight foward effort.
Warren & Ron, may you rest in Peace.
Old 06-05-2006, 07:26 PM
Elombard's Avatar
Heath Kit...havent heard that in a while :-)....I think the megasquirt is a big step past heathkit.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 06-05-2006, 07:52 PM
someonedid do that, they ran a system from an 80's s10 on his 2.7. I remeber seeing here on PP a few years ago. Guy swears it was pretty easy
Old 06-05-2006, 08:54 PM
Warren Hall Student
Bobboloo's Avatar
I remember another guy who used a Buick EFI setup.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 06-05-2006, 10:17 PM
beepbeep's Avatar
MS is better beacuse it allows continual re-programming. Using Ford/Buick/whatever OEM ECU would require EPROM-burner and opening of the box every time you want to change a parameter.
Ford EDIS is already used as it is.
Thank you for your time,
Old 06-06-2006, 01:32 AM
Slumlord
Porsche_monkey's Avatar
Someone on the board installed a GM six cylinder EFI system. Using all the same sensors and fuel injectors I guess you wouldn''t need to reprogram. I beleive it ended up looking like a home made EFI system.
Megasquirt seems to be the economical way to go now.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 06-06-2006, 04:48 AM
