74cookiecutter's Avatar
Lowered the Rear end
Ok, i'm continueing my education on discover your limits.... I lowered the front suspension including re-indexing the front torsion bars. That went ok.
then,
To quote raceProEngineer- "the rear is much more difficult and takes considerably more time" No joke!
after reading three different published articles and three or four threads I decided it was within my abilities (except the corner balance and alignment).
4 nights later and it's still not right. Getting the da** spring plate stuff loose and off the first time was almost impossible. (Two mechanics; my ass, wayne!)
started out around 27" rear ht now its 24.25". The first attempt put the wheel well on the tire!
Now its about 1/4 above the tire on the rt and 1/2" above the tire on the Lft. Target ht is 25" in the rear.
I have no clue as to how jacked up the camber and Toe-in will be when i'm done. I hope I don't have to drive far to get it balanced and aligned.
It sure looks better though.
Last pic is starting point.
what oil?
Old 06-05-2006, 07:47 PM
Elombard's Avatar
Your OK
Go back and re read the alignment stuff you can set that too. Your almost there! I would suggest getting it close then take a week off. It will go much better after a few days to clear the head!
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 06-05-2006, 07:50 PM
