David Hernando
Guest
Posts: n/a
Steering Problem
I have an '82SC Targa. The steering feels spongy not tight. I have just had a 4 wheel alignment. It pulls a little to the right. The alignment shop thinks trhe steering rack has some play. The shocks seem fine and a visual inspection of bushings looked good. The steering wheel has a little bit of play almost none but when going over a bump it sort of kicks back. What should I check for? It is not lowered 25" 3/4 from ground. Is there adjustment at the steering rack?
Old 06-04-1998, 09:17 AM
d_lazarus
Guest
Posts: n/a
Mebbe tie rod ends....
Old 06-05-1998, 03:04 PM
Author of "101 Projects"
Wayne 962's Avatar
That sounds like a good guess. I would start replacing things a little bit at a time, as they are wearing out anyways with age on a 16 year old car. Tie rod ends are a good place to start. Also check your rubber bushings at the rack and consider upgrading to Turbo Tie Rods as they are much stiffer...
Just a thought...
-Wayne
Old 06-05-1998, 08:13 PM
