Unhappy Need Help, 73 911E will not run when warm
She starts great when cold. Once the engine warms up the engine dies and will not restart until the engine cools down. I am at my wits end! Does anyone have a clue?
Need Help
Old 09-09-2007, 03:01 PM
Early_S_Man's Avatar
Porsche Crest
Jack,
Check your points.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 09-09-2007, 05:49 PM
Autodidactic user
David E. Clark's Avatar
Jack,
This chart has helped me in the past:
© Up-fixin der Porsche, Volume IV, page 270 Posted here for educational purposes only.
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Old 09-09-2007, 06:10 PM
Grady Clay's Avatar
Cool
Jack,
Welcome to the Forum
You will find a lot of help here.
Does the 911 ‘progressively’ quit while driving a longer distance as opposed to just not re-start when hot? Is it more prevalent when warmer ambient? Is it more prevalent with less fuel in the tank?
If so, a not-too-unusual problem to investigate is your fuel pressure. That is easily done with a “T” fitting, a long length (10') of inexpensive hose from NAPA, some clamps and a 15-20 psi gauge. The T-fitting goes in the hose from the rear-most line from the fuel filter console. The long hose allows you to monitor the pressure while driving.
Make sure there isn't the slightest gasoline leak from your test set-up. Gasoline is probably the most dangerous substance you normally ever come in contact with. A burn injury is one of the most devastating.
What you are investigating is the common problem of fuel tank rust particles getting on the filter screen at the fuel tank outlet fitting. When driving (and getting the engine up to temperature) the particles accumulate on the screen. When stopped (and engine cooling off) they fall off.
If this is the issue, the fuel pressure will be normal when cold and drop to near zero when after driving and up to temperature.
If confirmed, the next test is to inspect inside the fuel tank through the fuel level sender port. Tale a long (2’) swab and see what is on the bottom of the tank.
If this is the problem , the cure is to remove the fuel tank for a through cleaning and possibly replace the screen filter.
There are other possible cause of this symptom but this one is common and easy to eliminate.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 09-10-2007, 05:58 PM
Thanks,
If the points are a problem, will the dwell change as the car warms up?
Old 09-10-2007, 08:31 PM
This diagnosis chart is a great reference. Thanks,
Old 09-10-2007, 08:33 PM
Thanks Grady,
I recoated the tank once but the car has sat for awhile. Because I let it sit to long is why I am having this trouble. I had to have the MFI rebuilt again and once I reinstalled the pump I started having this problem.
What should the pressure gauge read on the fuel line if the fuel pump is working properly.
I will also check the tank screen.
Is there a chance the fuel mixture on the rebuilt pump is too lean?
Old 09-10-2007, 09:20 PM
The fuel pressure should be about 14PSI but the main thing is to look for a change as the engine warms up.
-Andy
Old 09-10-2007, 09:24 PM
Banned but not out, yet..
RSBob's Avatar
If your plug wires are old you may consider replacing them (old wires when hot increase resistance - and really old ones will make your car virtually undriveable). The cheap and easy way is to swap with some one and see if that's it.
Old 09-10-2007, 09:45 PM
Send a message via Yahoo to mobius911
And another possible cause- I had a faulty CDI that only quit when hot.
Jeff
Jeff Jensen
1973 911
Old 09-11-2007, 05:06 AM
If it runs good then stops suddenly, check the ignition for spark when it stops hot. The coil or CDI could be at fault.
If you have spark, look at the fuel delivery system.
Ed
'69 911E 2.7MFI ;996TT;987.2 CaymanS
'71 Volvo P1800E wife's; AMG SLK wife's
'71 Volvo race car
944S; 986S ; 734WHP drift car (son's)
Old 09-11-2007, 07:04 AM
