you see Arthur...
front bilstien struts
Noticed some knock from the front end while driving last night. Sounds like a shock topping out. I have green bilstien struts up fron on my 82 SC. My question is can I just replace the shock inserts for siad struts, and what is the procedure? Do I need to remove the strut from the car? I searched the forum and only found one thread. Any help or insight would be greatly appreciated.
J 82 911 SC, Cat bypass, Flowmaster 1 in 2 out lightweight flywheel and backdated heat 06 Cayenne S 00 ML 55 AMG Santa Cruz Bullit |
You can replace the inserts. I know there are a ton of threads regarding this job so try the search again. The strut will actually stay attached to the lower control arm while you replace the insert. Pretty easy job really.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
durn for'ner
Yes, plenty of great info right here. I changed them myself, and believe me, if I could do it anyone can !! Of course, I have Boge struts so I did not have to struggle with the roll pin, that I would think you have with your Bilstein struts. Search for changing shocks, you will find two weeks of good reading.
Good luck !
Markus Resident Fluffer Carrera '85 |
you see Arthur...
Thanks. I will search again. Always great info here.
