Banned
msd blaster coil problem
anyone else have a problem get the wire from the distributor to the coil? it just doesnt want to stay attach on the inside. Im using magnecor wires. Anyone else had this prob?
Old 06-12-2006, 10:16 AM
Early_S_Man's Avatar
Porsche Crest
Is this the High-Vibration epoxy-filled, or the slightly larger oil-filled one?
You might try one of two strategies:
1. Loosen the omega-shaped coil clamp/bracket and slip the coil down a bit towards the distributor.
2. Get the relocation coil bracket used on engines with factory A/C ... it moved the coil downwards about 3" - 4" on the slant of the fan housing to give more clearance for the A/C condenser coils hanging under the deck lid.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 06-12-2006, 10:41 AM
