3.2 Lowered Before and After...is it Too Low?
Before Lowering: Euro Height.
One and a half inces lower front and back. Ride much softer now...experts is it too low?
Euro 1989 Carrera 3.2 Paint Code L 693 Stone Grey 45,000 kms logged Last edited by Rad Hatter; 05-11-2006 at 07:01 AM.. |
I think it looks nice myself. The rear might be a shade too low relative to the front- I believe that you are supposed to look for a 1 degree slope on the rocker (back slightly higher than the front)
I like that ride height, but do you feel any uncomfortable inside. What about mine, would you think is too low ?
eyue 85' Carrera Coupe 93' 3.6 Turbo |
Its a little low for my taste....but it is somewhat subjective...if you do a lot of track time it might be ok....but for general street driving I think you might find issues with the ride height....only way to find out is drive it for a while...
Don Booth 87 Carrera Coupe (Current) 70 911 T Coupe 74 914 |
looks fine... if you don't rub you're all good.
Silver '88 RoW Carrera Grey '06 A4 Avant |
I would have left it alone at Euro height.
Feels very SOFT
The ride feels spongy and soft --like the rear shocks are bottoming out> but no rubbing or knocks though.
Just re- measured I asked for 24.25 Rear and 24.5 Front After driving it home I remeasured it Its 23.5 Rear and 24 Front Looks great though???
Euro 1989 Carrera 3.2 Paint Code L 693 Stone Grey 45,000 kms logged |
It looks great, it shouldnt rub, leave it as you have it now.
Matthew “Sometimes the questions are complicated and the answers are simple.” |
Still Doin Time
The front looks spot on but the rear is too low IMO. The rear tire is too far up into the fenderwell compared to the front.
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
you mean should be the same ?
Did it ought to be level with the fender wall like the front?
cheers Rich
Detached Member
Raise the rear a little.
Hugh |
Recreational User
I thought it was fine before. If the ride is too soft I'd put it back where it was.
I dig it....I think it looks perfect.....tell me how I know (just finished this myself)....BTW how is the rebuild on your friend's red 930 that got tangled-up?
![]() Yasin
Ole Skool - wouldn't have it any other way |
Your car looks great>>
Will drive it for a few days and see who it goes cheers
Ideal height IMO....
This is the height I was hoping to achieve>>>
I wonder if the susp. is too low and the geometries are screwy? The front looks fine, i think the rear looks a little low aesthetically but I have seen a lot of cars with the "lower in the rear" look lately, maybe the tuner shops have found this faster at the track? DWSD's car comes to mind. I am assuming they re-aligned after they lowered?
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
IMO, It looks about 3/4 on an inch too low in the rear. The front looks great.
It is amazing the difference your new Fuchs wheels make. That is one beautiful Carrera!
Jack 2007 GT3 gone but not forgotten: 1987 Carrera IROC backdate, '89 Carrera M491, '96 993, '93 964 RSA(two), '00 996, '97 Boxster, '79 911SC, '78 928, '76 924, '75 914, '74 911, '74 914, '72 911E, '72 911T/V, '71 911T, '70 911T, '66 912, '65 356C, '61 356B roadster, '60 356B |
Seems majority think its too low>>>
Yep I tend to agree >>
I was advised to go 24.27 front and 24.25 rear, that's what I asked the garage to do...BUT Its now 24.0 and 23.5 rear. If youre saying the front is fine at 24 then where should I set the rear ? Thanks
Designer King
Redhatter,
Thanks for referring to my car as the perfect ride height. I can tell you that the measurements @ the centerline of the wheel to the arch are F 24 7/8" and R 24 1/4". The arches are S flares. The tires are 205/50-16 Fuzion ZRi on 7" Fuchs, which should have a dia of 24 1/8". So far, in normal street/highway driving I have been OK wrt rubbing and bottoming.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
