I ROC!
Engine in process of being re-assembled:
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Forgot another photo of the head:
I ROC!
And the engine complete (that's Ben's muffler mounted to Bischoff HE's [with the flanges flipped] the tailpipes haven't been welded on yet until engine is installed. Auto Assoc went so far as to flowbench the muffler to determine proper cam selection. BTW- they say the muffler flows pretty well:
![]() ![]() ![]() ![]() ![]() ![]() The G50 being rebuilt with custom gears, steel synchros, etc. ![]() ![]()
I'm a loser, baby.
Yahtzeee!!!
1979 911 SC |
Huuuzzza~!
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
I ROC!
Scott at Auto Associates was kind enough to send me some photos of their awesome work.
GTP's just barely fitting in the Lindsey's: ![]() ![]() ![]() Extended & baffled oiltank: ![]() ![]() ![]() Ben's "R" muffler w/outets welded & fitted (I'm told they sound awesome) ![]() ![]() Red oil light & amber alternator light (if belt breaks)
I ROC!
More Pics:
RSR guages (recalibrated- not originals) ![]() I get chills looking at it! ![]() ![]() Just a taste of some of the awesome cars Auto Associates works on: ![]() ![]() ![]() ![]() Air inlet screen welded on to HE's (AA fitted two electric fans that will suck air through the HE's for cabin heat rather than big hoses running from engine fan) ![]() ![]() Custom aluminum watershields barely visible (attached to decklid to keep water out of the ITG filters...K&N watershields lose up to 20 hp on an engine like this, so I wanted the ITG's)
AWESOME......tit$ on ice
![]() you are taking the early lead for Pelican vehicle of the year! I think Matteo owns 2007's trophy. Are you using heat? How does it work? Doug
1971 RSR - interpretation |
I ROC!
Hi Doug, yes it will have heat. Instead of a big hose running from engine fan down to one HE & then a crossover pipe, Auto Associates plumbed two small inline electric fans that will suck air into the HE's (through those metal screens) and up into the car. It eliminates alot of cumbersome tubing that doesn't look good either.
Wow. You're doing some cool stuff on/to your car. I didn't see ANYWHERE where you skimped! When do you get to test drive it?
EDIT - sorry, I read the previous page and it appears that you've got it at home! That's great!
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
Loose nut bhind the wheel
Holy $hit !!! OOPS can I say that here?
Ed 1970 911S Targa 2.7RS MFI dual plug 10.5:1 1974 260Z SCCA ITS 1998 M3 |
mpeastend: Awesome car!! Very very nice
tip on the twin plug distributor: Get a small section of flex tubing to go from the air outlet on the fan shroud to the inside of the distributor. 12 plug dizzies build up a lot of ozone inside the cap, and the extra air serves to disperse and cool it off i don't have a pic to post, but perhaps another reader can post
1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race) |
I ROC!
Everyone, thanks for the kind words!
Tom '74 911- no it's still at Auto Associates & I haven't driven it yet. The motors been started but not dyno tuned yet. They are waiting for a warmer day to get the carb jets right. |
I ROC!
Thanks TRE Cup!!! I'll mention that to AA!
Midwest R Gruppe
Great project and thanks for sharing with all the photos. You are giving me some great ideas for my IROC clone. It is race ready at the moment, but not street legal. That would be a pretty rough ride and it was street legal not too long ago - would like to make is so again someday. Love your choice of color. Mexico Blue is the bomb! Mine is bright yellow, which I did not choose - yuk. Gonna maybe change that someday.
Scott 69E Coupe 2.2S LtWt 73.5T Coupe |
I ROC!
Thanks Scott...Mine is street legal, but barely. I made sure the chassis would be exempt from emmissions due to age but do your research as it varies wildly from state to state. The car is for 90% track use & 10% Sunday drives. Auto Associates is great to work with...they listened to what I wanted from the engine (maximum power for track w/nice hp/torque profile, driveability on street, decent idle, reliability), built it from there and geared the tranny to match the engine's profile. They chose cams based upon engine/carb & flowbench results of exhaust (bischoff HE's & Ben's muffler) to eliminate flatspots. I wanted 380 to 400 hp which they say I should be able to achieve (they just aren't sure due this being one of the first of MB911's mufflers they are using in this type of build). Only the dyno will tell for sure. I'll have to post specs on the engine later but cams are somewhere between GE80 & GE100 specs. 50mm PMO's, MSD6A1 twin ignition, GT3 crank, 964 case, solid rockers, RSR pistons & cylinders (the real ones that require all the extra machining), RSR specs on heads with porting and large valves (stainless) round out the major items. In order to get the hp & torque I wanted, compression is at 12.5:1, requiring 110 leaded (a decision I may come to regret as local sources for fuel are at $7.75/gal & rising!)
Very nice Mike it looks like it's all coming together very nicely.
![]() I bet you can't wait to get it out. ![]()
Thanks! Don Ramsay E Mail: aircooledclassicsporsche@gmail.com The father of 964 Backdating! www.aircooledclassics.co www.facebook.com/AirCooledClassicsPorsche/ www.instagram.com/aircooledclassicsporsche/ |
Friends of Warren
Woohoooo.... I bet you can't wait to have it home.
I love the way you positioned the JRZ's canisters. Sweet! Also that engine tin is top! Fantastic... |
Damn...
Cars like this and Matteo's make my hours slaving in the garage on my own Mexico Blue IROC project seem worthwhile! Subscribed.
Earlysport _____________________________________ 69 911E, 69 911E RS Rep 3.0L Hotrod, 77 930 IROC REP 3.6L SOLD, 968CS SOLD, 987 Boxster S SOLD |
I ROC!
Thanks Doc, Matteo & Craig...I appreciate all the comments! It took 2 years but will be worth it!
Looking pretty sexy!
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
