power window problem on 1991 964 C2
Okay, I goofed up. I have a sticky passenger power window switch on the driver's side door panel that didn't return to the neutral position after I raised the window. In other words it remained on with out my noticing it in the up position. Now the window will go down but not up. Did I burn out the relay or the switch? I should have repalced the switch when it first started sticking, lesson learned. What to do?
Platinum Member
Well you have to change the switch anyway...... You could also swap switches to debug, they are the same.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
dad911 is right on it. The switch - swap out to test. These switchs do this all the time. Has happened to me three times!! I now have an extra switch with my all the time.
Earl
78 SC Coupe 93 RSA (Gone) |
