19 years and 17k posts...
azasadny's Avatar
I sent my odometer to North Hollywood several years ago and they rebuilt the unit for a reasonable amount of $ and it's worked fine since, no problems...
Art Zasadny
Learning the bass guitar
www.ford.com
Old 08-11-2006, 07:31 AM
Can't seem to get the needle off, no matter how hard I wedge my fingers under neath. The odometer.com site seems to contradict itself by saying don't put any torque on the needle and then goes on to say move the needle past the stop then gently twist the needle structure to remove it...WTH, since when are twisting force and torque not the same thing?
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 05-27-2009, 04:36 PM
Somatic Negative Optimist
Gunter's Avatar
Some may come off easy and some don't.
Besides, even if the needle comes off, the calibration is lost.
If you try too hard, you'll brake the needle and/or the small shaft and it'll cost more to fix.
Some people have replaced the broken plastic gear without removing the needle; very difficult.
Pelican or North Hollywood.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 05-28-2009, 06:39 AM
Gunter, I'm confused as to how removing the needle causes loss of calibration....on my '88 the needle is pointing directly at the "first" white dash on the speedometer's face. Couldn't I just press the needle back on and make sure it was pointed at the right spot or am I missing something about the calibration? Do Pelican and NHS somehow replace the gear without removing the needle? The outer brown gear on my speedo has basically turned to brittle jelly.
Thanks for the comments,
Buck
'88 Coupe, '87 Cab,
Old 05-28-2009, 08:55 AM
Automotive Monomaniac
Emission's Avatar
I just noticed that my odometer must have stopped working within the past two weeks (my trip odometer read 57 miles, but the tank was just about out of fuel!). The speedometer still works fine, however.
Contacting North Hollywood Speedometer (and Clock Company) today for a quote.
- Mike
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 10-31-2012, 12:02 PM
Retired, finally
SiberianDVM's Avatar
Mine too. I'm making a list of stuff to be fixed, almost every gauge has a glitch of some sort, might as well get them all done along with a repaint and LEDs.
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project
Old 10-31-2012, 12:47 PM
Originally Posted by Gunter View Post
That is one of those stupid myths that just doesn't die.
You can hit the reset button all day long while moving without any damage to the gears.
If you ever see the inside, and the mechanism, you'll see why.
If you don't believe me, send an E-mail to NHS and ask them about this issue.
Cheers.
I have found the sure-fire way to NEVER break odometer gears... Don't press the reset button EVER!
After breaking two gears gingerly resetting the odo (while not moving BTW and yes I don't believe that makes it any more likely to occur), my current set has lasted almost 200k miles using this simple trick.
HTH,
Chuck.H
'89 TurboLookTarga, 341k miles
Old 11-01-2012, 05:15 AM
Emission's Avatar
HTH,
Chuck.H
Pretty funny... then again, I don't expect to put another 100K on my rebuilt odometer!
Estimate from North Hollywood Speedometer is $130 plus shipping. I'm sending it out tomorrow.
- Mike
Old 11-01-2012, 12:56 PM
Whoopsies I was banned!!!
Esel Mann's Avatar
I'm seeing a lot of good feedback for NHS on repair of the gear.
The odo and tripo on my 964 speedo just recently crapped out. However in addition to that, when the backlighting is on for evening driving, the face has deteriorated to the point where the backlighting leaks through all over the place on the face.
Has anyone had NHS also redo the face as well? Cost? Quality?
Old 11-01-2012, 01:34 PM
Emission's Avatar
Shoot them an e-mail: info@nhspeedometer.com
My reply (and quote) arrived the same day.
- Mike
Old 11-01-2012, 04:08 PM
Emission's Avatar
As a follow-up, I shipped my speedometer to North Hollywood Speedometer on Monday. It arrived back today (Thursday) cleaned and repaired! Yes, that is 24-hour turn-around if you consider the shipping time.
I can't wait to get it all back together this weekend!
- Mike
Old 11-08-2012, 07:54 PM
samourai71's Avatar
has anyone tried changing all the gauges lights to led for better lighting?
I have to have my speedo fixed and figured I'd kill 2 birds with 1 stone.
and also change the template from miles to km.
I haven't found any pics of the led lighting.
Old 11-08-2012, 10:31 PM
Emission's Avatar
Some pics here:
Porsche 911 Custom Coloring and LED Lighting
- Mike
Old 11-09-2012, 08:13 AM
I can do it. $165, free shipping. Turn around is 2-6 days.
McQueens Inst.
6737 34th Ave sw
Seattle, wa
98126
Old 11-09-2012, 09:01 AM
tobluforu's Avatar
I pulled my tach a part and stopped when I could not get the needle off, so off it went to hollywood. I found a tach with a 7k redline, sent that with it and they replaced my T face with the one I found and it looks brand new.
How did a break my odometer, well I set the trip back to zero while driving. I Had read about not doing this, but had a brain fart, pressed it, said to myself, "uh oh". Sure nough, broken.
Old 11-09-2012, 10:49 AM
Emission's Avatar
Come to think of it.. that's how I broke mine! I was driving away from the gas station and I reset it!
- Mike
Old 11-09-2012, 11:18 AM
AutoBahned
RWebb's Avatar
use a fork to to get the needle off
Old 11-09-2012, 01:12 PM
DG624's Avatar
NHS is good but also expensive. It is easier to send it to them and have it done right. Make sure you remember how to hook up the wires...write it down because if you hook them up wrong it burns the speedo. Trust me I have expereince.
Old 11-09-2012, 02:05 PM
i just fixed mine using thrashers post and got the needle off with no problem by twisting it from stop to stop while easing it off.....when i was done with the repair i put it back in without the bezel and glass and calibrated the needle using my gps and once i had it dailed in i took it back out installed the glass and bezel then reinstalled it...sounds complicated but was pretty easy
Old 11-09-2012, 04:40 PM
Hunt3R's Avatar
I recently called NHS because my 911 odometer stopped working while driving a long road trip and I also asked about replacing all 5 gauge faces with updated white faces ($300) or replacing the lighting with LED's ($400) or all of that together including refurbishing all 5 gauges would be $1400 I was quoted.
I didnt send them to NHS though because I was told there's a 6 week wait right now and I mainly wanted my odom fixed so I could start driving again so instead I sent it to DNA Speedometer in Tampa, FL and got it fixed for $130 and returned within 4 business days of sending it.
Speedometer Repair and Odometer Repairs at Low Prices! Instrument Cluster Repair!
Old 11-10-2012, 04:24 AM
