78P930's Avatar
Removing Front Sway Bar
What is the trick to removing the front sway bar?
10 Ford Raptor
86 930
Old 06-28-2006, 08:29 PM
Now in 993 land ...
aigel's Avatar
Remove hardware and pull! If there is trouble, try jacking the suspension with your jack to the "normal" loaded position. Some motion lotion on the bushings may help as well.
George
81 SC (sold)
Old 06-28-2006, 08:38 PM
If you think getting it out is tough, wait until you try putting it back in! Lube it up and push out one end once the weight of the car has been taken off the wheels.
Do a search for sway bar installation and you should find some good tips.
Tony G
2000 Boxster S
Old 06-29-2006, 03:18 AM
safe's Avatar
Brute force and lubrication....
Magnus
Old 06-29-2006, 09:17 AM
I'm just about attacking this in the next few days...
I'm replacing mine with the thru the body type so my mechanic suggested me to simply grind off the old mounts with the bar in place. But otherwise, he also suggested brute force & lube.
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 06-29-2006, 09:20 AM
Thrasher's Avatar
Or, the "easy" way... while replacing my crossmember, I simply removed the three bolts that secure the front end of the a-arm and let it move a bit . That gave me plenty of wiggle room to move the a-arm. Since the a-arm is secured by three points, I don't see any way I could've disturbed my alignment, as long as you are sure you seat the a-arm back in the mount the same way.
So, you end up removing a few more bolts, but it's a snap to pull the swaybar out. You only need to do this on one a-arm, btw.
'84 Carrera Coupe - B&B Headers and one-out muffler; K&N Cone intake; Steve Wong Chip; Euro height and corner balanced; 171K Miles (9/12)
Old 06-29-2006, 09:26 AM
78P930's Avatar
GOT IT! Had a friend drop by and helped push in the bar end. Thanks for all the help.
Pat
10 Ford Raptor
86 930
Old 06-29-2006, 12:01 PM
