kide's Avatar
Line dangling by itself - what is this line for?
Hello all,
Today I was doing the valve adjustment and found this line that is not attached to anything. Does anybody know what this is for?
Please pardon my dirty hand... Thanks!
Old 07-01-2006, 03:07 AM
Formerly bb80sc
Vipergrün's Avatar
What year car? If it's an SC, I'd say it's a vaccum hose which goes to the decel valve.
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 07-01-2006, 07:05 AM
kide's Avatar
Opps. Cannot believe I forgot to mention the car specs.
It is a 1985 3.2 Carrera.
Old 07-02-2006, 11:34 PM
SteveM911's Avatar
Kide,
It should plug into the Ambient Air Valve, 2" size round valve
to the left of your oil filler cap as you look at your top picture.
See picture attached.
Steve (Strosek34)
86 - Carrera 3.4 LWT
www.impactbumpers.com
Old 07-03-2006, 07:52 AM
kide's Avatar
SteveM911,
Thanks for the post. I got around to look into the engine bay today, and found that the Ambient Air Valve was attached with 2 hoses already.
The one you pointed (arrowed "your hose" in the previous post) was about 1/2 inch (1.5 cm), securely attached to the valve. The one that is dangling is about 1/3 inch (1.0 cm), so it is a thinner hose.
Any more guesses???
Old 07-07-2006, 11:29 PM
aj88cab's Avatar
My '88 3.2 has three hoses running to the ambient air valve. Two larger hoses and a smaller one (your loose hose?) that attaches to the valve just above the larger hose on the side of the valve that is towards the front of the car. Hope that helps.
Good luck
Andrew
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 07-08-2006, 05:35 AM
kide's Avatar
Thanks aj88cab -
I check the ambient air valve again, and there was a nipple at the top of the valve, so I plugged the wire there.
I checked through the Pelican website and found a couple of mentions about various versions of the valve, and one that has a nipple at the top, so I am pretty sure it is suposed to be like this as in the picture below:
Thanks much.
Old 07-16-2006, 01:01 AM
87coupe's Avatar
Did you notice any difference with it now plugged in? Any change in idle?
ßrandon
Old 07-16-2006, 01:13 AM
kide's Avatar
No, I didn't notice any difference in idle or anything else.
I wonder what this valve does... I guess the line is supplying the ambient air pressure or temperature? If so, then connecting the line won't make much difference at start, when ambient (outside) condition is similar to that of the engine bay.
Maybe its function kicks in at high stress conditions, which I haven't tried.
Old 07-16-2006, 08:50 PM
911FL's Avatar
I chased down the missing hose that you had dangling. My valve looks the same but it looks as though the nipple has broken off. There must be a way to retrofit a new nipple to the top. Anyone gone through this?
Dan
“Out on some Sonoma County road, with Jimmy Dean and Steve McQueen”
1984 Carrera Targa
Old 07-29-2006, 01:11 PM
kide's Avatar
(It has been a long while but...)
I had the engine checked by a Porsche mechanic and he confirmed that the vacuum hose (dangling hose) was supposed to be plugged at the top of the ambient air valve, as shown in the photo above. He said it shouldn't make much difference in drivability. Wonder why it's there.
Old 10-24-2006, 09:22 PM
defcon65's Avatar
It must be a common problem on 3.2s, mine was disconnected as well, probably displaced by someone fumbling with the filter box clamps. I also noticed no change in the way it ran after reconnecting it to the top of the valve.
Joe
85 Carrera
64 Honda Dream - for sale
71 Hodaka Super Rat - keeper
Old 10-25-2006, 11:11 AM
I have 1985 also. It looks like you got it corrected.
My thought was it is the rubber hose with cloth brad which connects to the back side of the air filter housing. I thought the other end went to oil reservoir. Maybe it goes to the ambient air valve.
I discovered this while replacing shocks.
Old 10-25-2006, 02:47 PM
