			 Carbon Emitter
			>Maybe once a year we should put the old chip back in so that we can appreciate how good life has become.
				I put my stock chip and cat back in to pass smog a few months ago...felt like I had big Aunt Bertha in my passenger's seat. ![]() >I'm not sure I understand the claim of more performance AND better fuel economy? I don't know *how* he does it, but supposedly he optimizes the mixture during part throttle cruising for fuel economy and optimizes heavy throttle for power. Whatever he does, it works.  |
			Just finished upgrading my '86 with Steve's chip, Fabspeed cat bypass, and M&K 1in/1out muffler.  Very pleased with the quality of the products, performance, and sound.
	1986 911 Carrera 3.2 Coupe 1969 911 T (sold) 1970 914 my first P car (sold) Life Has Its Rewards
			Steve, if you are still out there, going 1 3/4" euro headers with megaphones w/noise suppression in a 3.6 72. K&N cone AF.  have you a chip for this setup? thanks-Bill
			Absolutely - the chips developed for the 3.6 964/993s make just as great an improvement as they do on the 3.2s.  Just recently, we pulled 253 rear wheel HP on Tyson Schmidt's '94 C2 on a Dynojet, which assuming a 15% transmission loss factor, is 297 HP at the engine.  This was on 91 octane pump gas, with just a cat bypass and open airbox cover.  Really noticable is the increase in low and mid end torque - a crack of the throttle will induce tire spinning throttle oversteer in turns.
	We also chipped his friend's '93 RS America with equally impressive results. Belonging to Matt Lowell of a Matt's Greenwood Autocare in Seattle, a modified exhaust system with headers from a 993 was installed and the car was baselined on both a Dynojet and Mustang dyno and measured about 220 hp at the wheels. A rechip optimizing the fuel and ignition for 93 octane, the engine redynoed at 273 rwhp on the Mustang, that's a 54 hp gain at the wheels. Correcting for a 15% transmission loss, that would be 321 hp at the motor. YMMV, but the transformation to this car was amazing.  |
 Steve W, I have an '84 RoW and plan to install a Fabspeed pre-muffler, and M&K 1 in/1 out exhaust. Do you have something specific? Also, what is involved in chipping it in my '84? I'm not a total newb when it comes to chipping cars (owned an '00 GTI 1.8T and a '99 Audi A4 Avant 1.8Tq), but have read where there's an extra wire that needs to be ran for 'early' 3.2s. Is this true? Thanks, Mike
	Mike '84 Grand Prix White RoW Carrera  |
 The baseline was done AFTER the exhaust install? Was there a baseline done before it? Then the chip alone produced the results? Without the exhaust, would the gains be the same? Or did the chip help get the most from the new exhaust, and vice versa? I guess what i'm getting at is that often its a combination of thigns...a synergy, that yeilds the best results. And...do you do 944S2 s???    (probable SCCA IT race car)
	Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]  |
			 Senior Member
	2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB  |
			 Carbon Emitter
	Yep. I did the mods one at a time...first one was the cat bypass and sport muffler, then the chip. Both of them made a big difference separately and together. The chip is a part of the complete package as SW will tell you...  |
			 Large Registered Member
			I see there is a different chip for stock vs. modified exhaust...  Is there more chip modification to be made if a cone filter, or K&N filter with the cover modified?
			I'm running a stock muffler, but with the cat bypass/pre-muffler. Also a K&N air filter... '85 3.2 By the way Steve, Happy 4th to you!
	'85 Carrera Coupe, Marble Grey #118 JP/R6 '93 Lexus SC400, '00 Ford F-150 '70 911T- 2.7 (SOLD)  |
			Thanks Patrick - happy 4th 2 u also!  The difference with air filter mods are so subtle, there is point in chip mods for such.  There are greater variations between car to car just in the motor itself.
			Thanks for the reply Steve!
			Those numbers above are impressive. I've been running another aftermarket chip for almost 5 years. Performance improvements were impressive, but my MPG has suffered, even when trying to drive a couple of tank fulls with economy in mind... I've been thinking of trying your CHIP, as I've read that many people see even improved mileage over the stock CHIP? I just popped in the OEM CHIP for kicks, to see if mileage would improve. I've only driven a half a tank, but it looks as if I will get an extra 100 miles out of this tank than normal... Also, I've noticed that the car seems quite sluggi
			Ooops!
			Sluggish. Performance difference between the 2 CHIPS is dramatic.... I guess I'm looking for the best of both worlds... Performance when I want it, and good MPG when I choose to drive like a sane person... I do have the 24 pin chip, so is there any real advantage to the different mod you have for upgrading to the 86-89 model? Mine is an '85. Thanks again! Patrick
			Patrick, fuel economy varies from car to car in as much as cars with stock chips can vary their fuel consumption from 17 to 24 mpg.  The chip is more efficient at converting fuel into energy, but it also unlocks the potential to produce more throttle response and acceleration power, and if utilized increases consumption by a proportionate amount.   MPG is like going to a buffet, given the choice a person might tend to overeat.  Generally, low speed stop and go city driving can be anywhere from the same to about 2 mpg less if driven more aggressively.  On the other hand, high speed driving, even at 80-90 mph with lots of acceleration bursts, fuel efficiency normally increases by 2-4 mpg over stock because of the more efficient energy extraction.  Really depends on one’s driving style, but best way to summarize it is that the more high speed and or steady state your driving conditions are, the greater the increase in mpg you'll gain over the stock chip.
	For U.S cars, there is an advantage to the 4k programming over the 2k chips that have traditionally been sold for 84-86 cars. 2k programming has tight limitations on how much power and throttle response is achievable. A 4k program makes significant improvements in low and mid end torque, idle quality, and eliminates the sub 4000 rpm lag, with power coming on as soon as 1500 rpm, that is not possible for a 2k chip to replicate. All 84-86 chips I’ve provided in the past few years have been 4k, and as such may require a 4k jumper mod to the DME if not already enabled. You are welcome to try it and compare it to your chip for a while. To date, it seems everyone who has, has not gone back.  |
			Thanks Steve!
			Exactly the info I was looking for... My work commute typically occurs during off peak traffic hours. The majority of my drive is an easy steady freeway cruise at about 80mph. With the other chip, I struggle to hit 20 mpg. I believe with the stock chip, I'll be hitting 22-24 mpg. I would love to get close to that with your chip, and still have the performance enhacements when I jump on it. Do you include some thorough instructions for making the mod? Even with my large fingers, I have the skills to remove the chip with no problem. Is it a just a simple soldering job for the 4k upgrade? Thanks! Patrick p.s. I was with the SOCG caravan up to the Ventura Show, and met you for the first time. You were gracious enough to take the picture below with my camera! I'm the third large guy from the left...
			Wow..that is a staggeringly impressive plot. If it were anyone else, I'd be suspicious!
			I think I'll be converting a 944S2 into a race car next year. Would love to see the same chip magic!
	Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar. '11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.  |
 I agree, the numbers look very good. Very impressive to me. Hopefully, I'll be able to do this in a month or two... Later, Mike
			The 4k mod is very simple, requires you to clip off the old jumper and solder in the new provided jumper.  Illustrated instruction are included, however it's mostly the 84s that need the mod and chances are good you don't need to do it.  By 86, almost all the DMEs were already 4k enabled.
	4K mod instructions  |
			Mine's an '85...  I'll take a closer look tomorrow...
			So if I wanted to take advantage of the 4k program, I would also order a 24 pin chip for '87??
			I've been seriously considering buying a SW chip.  To me it's an issue of whether it'll damage my engine in extreme conditions, which the factory had to take into consideration when designing their setup.
					Honestly, some of you guys with the breathless claims and lack of information are making it somewhat difficult to cull through the BS that surrounds most chip claims. In the world of automotive aftermarket equipment in general, most of the stuff is worthless if you know what I mean. Um, and Halle Berry is a freakin awful actress. Great lookin lady, but she can't act.  |
