78P930's Avatar
Replacing Dash on a 78
Anyone know if you have to remove the windshield to replace dashboard on a 78?
Pat
10 Ford Raptor
86 930
Old 07-03-2006, 06:00 AM
Work in Progress
Rich76_911s's Avatar
Pat, yes you do have to remove the windshield to remove the dash. So if you are replacing the dash you will also need a new gasket for the windshield. Because it is impossible to get the black (or chrome) trim that surrounds the windshield out without bending it, if you do not use a razor knife and cut the windshield gasket.
101 projects has a full report on replacing the dash, and also window removal and installation. If you do not already have the book I highly suggest you pick up a copy.
http://www.101projects.com/Porsche-101/Common/order.htm
Rich
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 07-03-2006, 06:13 AM
