-   -   well finally started the install this morning (http://forums.pelicanparts.com/porsche-911-technical-forum/291882-well-finally-started-install-morning.html)
jbrinkley 09-03-2006 05:40 AM
no changes, just a stand off from the old airbox mount hole to hold up the AFM better, keeps it more stable and supports the afm since the airbox isn't holding it up anymore. Should keep the stock boot connected to the afm as well since it's pretty much secure there now. http://forums.pelicanparts.com/uploa...1157287196.jpg
safe 09-04-2006 05:06 AM
Slightly off-topic, but has anyone tried a centrifugal compressor?
The installation of one would be easy. No exhaust modifications, no oil lines (self contained) and the characteristic of the engine would be like a N/A engine.
I have no experience with them but I read that they get their max boost high in the rpm typically 1000 rpm before red line.
Wouldn't that suit our k-jetronic engines that loses power over 5000 rpm?
mb911 09-11-2006 06:12 PM
some more pics of the recent clutch job with some polished turbo parts for pictureshttp://forums.pelicanparts.com/uploa...1158023436.jpg http://forums.pelicanparts.com/uploa...1158023486.jpg http://forums.pelicanparts.com/uploa...1158023532.jpg
1fastredsc 09-13-2006 07:08 PM
Is that your wide band sensor mounted horizontally after the turbo? If i remember right when i was installing an LM-1 wide band in a 951 they recommended to install the sensor as close to vertical (pointing down inside the exhaust) as possible, with i think only 30 degrees of variance.
mb911 09-14-2006 03:57 AM
yup all O2 are suppose to be mounted that way but worst case I replcae it later (they are pretty cheap. the production models were corrected)
IlMostro 09-18-2006 11:48 AM
great thread, looking forward to hearing more!
Best Regards,
Daryl
Shorewood, WI
mb911 09-18-2006 01:42 PM
Best Regards,
Daryl
Shorewood, WI
you need to stop down and see it first hand
mb911 09-20-2006 12:36 PM
Originally posted by YermanCars
Ooops!!!
http://forums.pelicanparts.com/showthread.php?threadid=304663
yup my fault what you going to doSmileWavy
mb911 10-19-2006 05:45 AM
time for some updated pictures. the first being the setup we do for the ssi guys the second is the next generation of setup using a special SSI set up adapted by us and all of our pressure pipeinghttp://forums.pelicanparts.com/uploa...1161261804.jpg http://forums.pelicanparts.com/uploa...1161261814.jpg http://forums.pelicanparts.com/uploa...1161261823.jpg
out for now but I will update with more development as it comes available
mb911 11-02-2006 05:54 AM
updates are coming on new setup. stay tuned
JBO 11-02-2006 07:48 AM
mb911 - nice exhaust - is that fabspeed?? :)
mb911 11-02-2006 07:55 AM
No sorry its ours we make all our own stuff
quattrorunner 11-02-2006 11:55 AM
That "Y" looks like cast iron. Did you make that or source it?
mb911 11-02-2006 12:09 PM
the new 2nd versions are 347 stainless cast unit from ssi that we modify. we still offer the standard units for the standard ssis but this is specific a special ssi set up
paslantnose 11-19-2006 03:42 AM
Very impressed with your work Ben, looking forward to the updates !
JohnHickey 11-19-2006 04:26 AM
Wow
Goodday from Down under love the project Ive just purchased a 1980 sc, could you tell me if you did a top and bottom end on this before the upgrade commenced , expected horsepower after the mod? what else has been done to the engine, Please
mb911 11-19-2006 04:58 AM
I had done a top end about 10,000 miles before doing this but stock compression and It was night and day difference in performance.. I had it on a dyno doing AFR's but I am not going to quote the HP rating as speculation says it was not accurate. However at 3000 rpm it was producing 150 HP at the wheels ..
Anyhow here is a link for someone selling the ssi crossover super cheap, cheaper then I can sell one for
http://forums.pelicanparts.com/showthread.php?s=&threadid=315829&perpage=20&pagen umber=1
tony77targa 11-23-2006 06:40 AM
HAPPY THANKSGIVING EVERYONE!!!!!!
Today I am thankful for threads like this one!! Ben ... I ahve followed all your threads and find them packed with lots of information and closeup pictures ect and I am amazed at the speed of your progress... I cant wait to log on again and see where you are in the project...!!
mb911 11-24-2006 07:51 PM
well just a little bit of info on my engine after the overboost.
cylinder 3 has erosion and cylinder 1 in major scoring and the ring land is broken.
So note to self and everyone else be careful of the boost signal line and run a boost guage
tbitz 11-25-2006 12:50 PM
Overboost
Ben,
MSnS-Extra software (downloaded into MegaSquirt) has a overboost and over rev protection. It will cut fuel (and spark of you are controlling it through MegaSquirt) once the thresholds your program are hit. Could have saved your engine...
It is somewhat more complex than the standard B&G software, but probably worth the time spent learing it in your case.
Cheers,
Tony
