well finally started the install this morning
after waiting to get some projects done around the house and a paint job for a fellow pelican along with being busy with the regulated the business stuff I have finally started the turbo install. I will update my day to day progress if folks want to see it. here are some pictures. Oh and this is an 81 sc engine with tbitz efi running a wideband o2 and out (M&K) airbox.. and dansk early heat exchangers(same as ssis but not as nice)http://forums.pelicanparts.com/uploa...1152112948.jpg http://forums.pelicanparts.com/uploa...1152112995.jpg http://forums.pelicanparts.com/uploa...1152113035.jpg
I'm with ya and I'll take the spare.
oh hear are some pics of the car and the parts jerry this is the extra turbo I told you abouthttp://forums.pelicanparts.com/uploa...1152114006.jpg http://forums.pelicanparts.com/uploa...1152114059.jpg http://forums.pelicanparts.com/uploa...1152114100.jpg http://forums.pelicanparts.com/uploa...1152114116.jpg
yup, I'll take one of everything in the top picture. PM a price, and I'll call you, no hurry
jerry are you out on the rig right now?? Anyhow. I am going to mess with this the next days and gone for the weekend. Once I return monday I will hopefully be to the tuning portion of this. I need to figure out the timing curve that I need etc but once its up and running I will get your prices etc. But you can use all my prototype stuff at a greta price
looks great- how 'bout an install on a 3.2 Carrera?
Ben;
Looks really good. Keep up the posts so we can follow your progress. |
Subscribed :)
Can't wait to see how this turns out :) |
Looks very nice!
wow...can't wait to see it GO!
ok heres more progress as of 1 pm. 2 pics one of the oil drain. I need to make that connection. Any ideas??http://forums.pelicanparts.com/uploa...1152126013.jpg http://forums.pelicanparts.com/uploa...1152126042.jpg
well got the drain figured out. so take a break and get back to it tonight. Should be finished with all the plumbing by the morning.. then adjust valves change the oil and fire it up
Great stuff Ben. I can't wait to see the finished product installed and shooting flames :D .
I think when we talked I was thinking and saying PSI, So what I meant was .5 bar or 7.4 psi, up to but not over .7 bar or 10.3 psi.
So ya I'm going to scrounge up an IC somewhere. I was thinking of goingsuperfast's. |
here's a pic of an oil return line that may work (very flexible)
It's 5/8 oil return from 85-86 ford http://forums.pelicanparts.com/uploa...1152156005.jpg |
Thats A good idea. I almost have the problem solved> believe it or not I am having trouble fitting the an fittings on the hose. I never thought it would be so technical to fit a fitting on a hose!!!!!!
Got it running yet Ben? -DMA |
no swim lessons this morning and go away for the weekend early friday so monday is the day. I will work on it a little today and post picture updates
updates...cmon we need our fix! =o) I just love watchind the fab work involved in this.
well at a stand still. Had to order another AN fitting 37 degree non swivel so that it will make the distance. So no updates until next week
I have been thinking about this set-up too. Could you use a t-fitting on the oil pressure sender unit? I'm not sure if it has enough flow, but it should have enough pressure!! or tap into a carrera oil tensioner line? Using the pan bolt seems like a pain, unless you tap the sump plate...
Brad |
the oil feed is the easy part. You just t off of the oil pressure idiot light fitting. The drain is the semi hard thing!!!!!!! just really need the right parts
Could you tap back into one of the cam covers?
<this has been edited> Brad |
yes as you see in the one picture that is what we did. but making the conection is the hard part. it is a very short distance and a bunch of bends.
On mine, protomotive welded a spout to the valve cover, and there is a short section of high pressure rubber hose clamped on to make up for the alignment issues. You may wind up needing to do something like that to make up for the slight variances in alignment.
So Ben, for a 3.2 version of this, will you make a J-pipe adapter, or are you planning on the 3.2 people to have to buy SSI's? I tell you what, make it so the 3.2 people do not have to remove their HE's, and you'll sell these like hot cakes. Mine will be major surgery to remove. |
as for the j pipe. I need a car to eventually model off of here!!!!!! Anybody local??? |
I need some ideas from you folks as to what you would like to see for the wg tubing?? I just put the wastegate off shoot on there for functionality for now but I will redo this early next week to make it look nice.
Ferdinand is spinning in his grave. |
if you make it point out like your two out muff, that'd be cool.
I have a bunch of -6 AN stuff but I bet your not using that? -4? |
Excellent Job Ben!!!
Can't wait to see your end results. Are there plans to add an intercooler setup down the road? And I am wondering for the 3.2 version, are we going to have to get a special chip made? You can put me on the very interested list to purchase. Have a nice weekend and more pics please! |
Where the hell is the intercooler!!! C'mon Ben you know you need an intercooler. Are you using alcohol or water injection??
j.p. Ps. Nice welds, who makes the muffler? |
Ben,
Looks good. I must say they I've spent countless hours on trying to figure out the best way to plumb fuel lines. Fittings are always the problem. Anyhow, When I started looking at adding turbo to my EFI 911 I had similar issues. In the end I found a great little fitting that fits on the turbo. http://forums.pelicanparts.com/uploa...1084411261.jpg |
You can see it in these pictures:
http://forums.pelicanparts.com/uploa...1084851331.jpg http://forums.pelicanparts.com/uploa...1084851353.jpg |
If you haven't already done so have a look at this CIS to EFI (Turbo) thread I had started a while back:
http://forums.pelicanparts.com/showthread.php?s=&threadid=155247&perpage=20&highl ight=turbo%20cis%20to%20efi&pagenumber=1 |
All my "theoretical" calculations showed that the 54-trim Garret compressor was the best choice which is what I think you have.
The "on-center" exhaust housing isn't the best and is really an aerodynamic compromise for tight fits. I didn't go with the on-center housing. Instead I went with the more conventional "tangential" housing. |
Jerry without doubt the tail pipes will be in stock location. The question I pose is the Wg piping. what would you folks like to see??? Mostly just visually impressive is my question.. Tony did you get yours up and running?? do you have any downloads I can use for my megasquirt??? I lost most of my data I had saved with a recent computer crash. I will use the wideband to fine tune but I wanted to have a good starting point. Oh and yes intercoolers will come soon enough but remeber with low boost you will recieve demishing returns with an intercooler.. it when you start rising the boost levels that it is more important as there is loss in pressure with any bloackage (e.g. IC) I am going to shorten the muffler by about 3 inches so I can fit the 3 inch tail pipe in there (think tennis ball). The WG will also exit in 3 inch. I have my work cut out for me if it is going to be running monday evening. I am leaving in the morning until sunday evening |
Btw-wouldn't it be easier to work on that car if you had a lift? Dohh!;) |
oh man the lift is there just full of muffler boxes and muffler parts along with some other junk.. bring the carrera over we can turbo that
I like the fact that you chose to hook up to SSI's. Your system should spool up much quicker than a factory exhaust system. I can see that your work is high quality, like your other products. Keep up the good work! |
If your not already doing so you should upgrade to MSnS-Extra software. This will give you a 12x12 VE table that you will need with the Turbo. It also has rev limit and boost limit cutout features which is just what you will need. Cheers, |
| All times are GMT -8. The time now is 03:07 PM. |
