-   -   well finally started the install this morning (http://forums.pelicanparts.com/porsche-911-technical-forum/291882-well-finally-started-install-morning.html)
Brad01mc 07-06-2006 12:32 PM
I have been thinking about this set-up too. Could you use a t-fitting on the oil pressure sender unit? I'm not sure if it has enough flow, but it should have enough pressure!! or tap into a carrera oil tensioner line? Using the pan bolt seems like a pain, unless you tap the sump plate...
Brad
mb911 07-06-2006 01:32 PM
the oil feed is the easy part. You just t off of the oil pressure idiot light fitting. The drain is the semi hard thing!!!!!!! just really need the right parts
Brad01mc 07-06-2006 01:36 PM
Could you tap back into one of the cam covers?
<this has been edited>
Brad
mb911 07-06-2006 02:14 PM
yes as you see in the one picture that is what we did. but making the conection is the hard part. it is a very short distance and a bunch of bends.
david.avery 07-06-2006 02:17 PM
On mine, protomotive welded a spout to the valve cover, and there is a short section of high pressure rubber hose clamped on to make up for the alignment issues. You may wind up needing to do something like that to make up for the slight variances in alignment.
So Ben, for a 3.2 version of this, will you make a J-pipe adapter, or are you planning on the 3.2 people to have to buy SSI's? I tell you what, make it so the 3.2 people do not have to remove their HE's, and you'll sell these like hot cakes. Mine will be major surgery to remove.
mb911 07-06-2006 02:23 PM
protomotive smotomotive:D David I have seen that as well but I am 100% positive I have it worked out. the shorter I make it the less likely there will be any issues. I may make them out of solid line for the production models. it would seem the cleanest. I thought of the valve covers but I do not think that is as easy as this cam cover.
as for the j pipe. I need a car to eventually model off of here!!!!!! Anybody local???
mb911 07-06-2006 02:48 PM
I need some ideas from you folks as to what you would like to see for the wg tubing?? I just put the wastegate off shoot on there for functionality for now but I will redo this early next week to make it look nice.
ruf-porsche 07-06-2006 03:11 PM
Originally posted by irnwill
here's a pic of an oil return line that may work (very flexible)
It's 5/8 oil return from 85-86 ford
http://forums.pelicanparts.com/uploa...1152156005.jpg
Parts from a F.O.R.D.?????
Ferdinand is spinning in his grave.
jbrinkley 07-06-2006 03:15 PM
if you make it point out like your two out muff, that'd be cool.
I have a bunch of -6 AN stuff but I bet your not using that? -4?
Nashville84Cab 07-06-2006 03:34 PM
Excellent Job Ben!!!
Can't wait to see your end results. Are there plans to add an intercooler setup down the road? And I am wondering for the 3.2 version, are we going to have to get a special chip made? You can put me on the very interested list to purchase. Have a nice weekend and more pics please!
jpahemi 07-06-2006 03:46 PM
Where the hell is the intercooler!!! C'mon Ben you know you need an intercooler. Are you using alcohol or water injection??
j.p.
Ps. Nice welds, who makes the muffler?
tbitz 07-06-2006 04:34 PM
Ben,
Looks good. I must say they I've spent countless hours on trying to figure out the best way to plumb fuel lines. Fittings are always the problem.
Anyhow, When I started looking at adding turbo to my EFI 911 I had similar issues. In the end I found a great little fitting that fits on the turbo.
http://forums.pelicanparts.com/uploa...1084411261.jpg
tbitz 07-06-2006 04:37 PM
You can see it in these pictures:
http://forums.pelicanparts.com/uploa...1084851331.jpg
http://forums.pelicanparts.com/uploa...1084851353.jpg
tbitz 07-06-2006 04:38 PM
If you haven't already done so have a look at this CIS to EFI (Turbo) thread I had started a while back:
http://forums.pelicanparts.com/showthread.php?s=&threadid=155247&perpage=20&highl ight=turbo%20cis%20to%20efi&pagenumber=1
tbitz 07-06-2006 04:46 PM
All my "theoretical" calculations showed that the 54-trim Garret compressor was the best choice which is what I think you have.
The "on-center" exhaust housing isn't the best and is really an aerodynamic compromise for tight fits. I didn't go with the on-center housing. Instead I went with the more conventional "tangential" housing.
mb911 07-06-2006 05:20 PM
Originally posted by tbitz
Ben,
I found those as well. My cousin works for the largest supplier of hyd/fittings in the US. My issue was that I want that drain as protected as possible from heat. as for the turbo yes all of my turbo's are 54 or 57 trim. I did consider tangetal but chose this style for ease of muffler fittment and keeping close to the BAE design as to be able to supply sammy and thad with replacement mufflers if they so chose.
Jerry without doubt the tail pipes will be in stock location. The question I pose is the Wg piping. what would you folks like to see??? Mostly just visually impressive is my question..
Tony did you get yours up and running?? do you have any downloads I can use for my megasquirt??? I lost most of my data I had saved with a recent computer crash. I will use the wideband to fine tune but I wanted to have a good starting point.
Oh and yes intercoolers will come soon enough but remeber with low boost you will recieve demishing returns with an intercooler.. it when you start rising the boost levels that it is more important as there is loss in pressure with any bloackage (e.g. IC)
I am going to shorten the muffler by about 3 inches so I can fit the 3 inch tail pipe in there (think tennis ball). The WG will also exit in 3 inch.
I have my work cut out for me if it is going to be running monday evening. I am leaving in the morning until sunday evening
SLO-BOB 07-06-2006 07:44 PM
Ben, I'm on the fence (Not you Bob!) on an 87 Carrera. If I get it, you know I'll be paying you a visit. Hell-I'll be paying you a visit anyway to get a ride in your car!
Btw-wouldn't it be easier to work on that car if you had a lift?
Dohh!;)
mb911 07-06-2006 08:00 PM
oh man the lift is there just full of muffler boxes and muffler parts along with some other junk.. bring the carrera over we can turbo that
JK-81SC 07-07-2006 02:10 PM
Is there is enough room for the wastegate tubing to route into the muffler? I couldn't tell from the photos.
I like the fact that you chose to hook up to SSI's. Your system should spool up much quicker than a factory exhaust system.
I can see that your work is high quality, like your other products. Keep up the good work!
tbitz 07-07-2006 07:24 PM
No I haven't, but with all the turbo mania on the board I might get motivated to do so.
If your not already doing so you should upgrade to MSnS-Extra software. This will give you a 12x12 VE table that you will need with the Turbo. It also has rev limit and boost limit cutout features which is just what you will need.
Cheers,
