no changes, just a stand off from the old airbox mount hole to hold up the AFM better, keeps it more stable and supports the afm since the airbox isn't holding it up anymore. Should keep the stock boot connected to the afm as well since it's pretty much secure there now.
Slightly off-topic, but has anyone tried a centrifugal compressor?
The installation of one would be easy. No exhaust modifications, no oil lines (self contained) and the characteristic of the engine would be like a N/A engine. I have no experience with them but I read that they get their max boost high in the rpm typically 1000 rpm before red line. Wouldn't that suit our k-jetronic engines that loses power over 5000 rpm?
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
some more pics of the recent clutch job with some polished turbo parts for pictures
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Is that your wide band sensor mounted horizontally after the turbo? If i remember right when i was installing an LM-1 wide band in a 951 they recommended to install the sensor as close to vertical (pointing down inside the exhaust) as possible, with i think only 30 degrees of variance.
2007 Mazda 3 hatch 1972 Porsche 914 roller with plenty of holes to fix
great thread, looking forward to hearing more!
Best Regards, Daryl Shorewood, WI |
time for some updated pictures. the first being the setup we do for the ssi guys the second is the next generation of setup using a special SSI set up adapted by us and all of our pressure pipeing
out for now but I will update with more development as it comes available
updates are coming on new setup. stay tuned
mb911 - nice exhaust - is that fabspeed??
Brando
That "Y" looks like cast iron. Did you make that or source it?
Turbo powa! 1977 911s. it's cool |
Very impressed with your work Ben, looking forward to the updates !
Wow
Goodday from Down under love the project Ive just purchased a 1980 sc, could you tell me if you did a top and bottom end on this before the upgrade commenced , expected horsepower after the mod? what else has been done to the engine, Please
I had done a top end about 10,000 miles before doing this but stock compression and It was night and day difference in performance.. I had it on a dyno doing AFR's but I am not going to quote the HP rating as speculation says it was not accurate. However at 3000 rpm it was producing 150 HP at the wheels ..
Anyhow here is a link for someone selling the ssi crossover super cheap, cheaper then I can sell one for Elephant, Tarett, M&K, 930 Parts for sale
HAPPY THANKSGIVING EVERYONE!!!!!!
Today I am thankful for threads like this one!! Ben ... I ahve followed all your threads and find them packed with lots of information and closeup pictures ect and I am amazed at the speed of your progress... I cant wait to log on again and see where you are in the project...!!
89 Mercedes 300E 77 911s TARGA 79 3.2 widebody 79 911 SC TARGA 97 BMW Z3 |
well just a little bit of info on my engine after the overboost.
cylinder 3 has erosion and cylinder 1 in major scoring and the ring land is broken. So note to self and everyone else be careful of the boost signal line and run a boost guage
Overboost
Ben,
MSnS-Extra software (downloaded into MegaSquirt) has a overboost and over rev protection. It will cut fuel (and spark of you are controlling it through MegaSquirt) once the thresholds your program are hit. Could have saved your engine... It is somewhat more complex than the standard B&G software, but probably worth the time spent learing it in your case. Cheers, Tony
Tony '78 911SC with BITZRACING EFI conversion kit |
