enjoying toes out
really enjoy toe out cornering more so than toe in tracks nicer and steering seems more responsive my toe out is 1/4 inch is this a problem as 1/8 recomended? more wear on bearings? thanx looking to track for 1st time in 2 weekson 21st
Old 07-10-2006, 09:20 PM
Toe out is fine for track work. It will wear your tires quicker and tend to wander just a bit more.
The best setup for the track, camber and toe, usually aren't the best for the street and tire wear.
How's your tire budget?
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 07-10-2006, 10:01 PM
dimps8's Avatar
I suspect you'll have massive bumpsteer. I hope the roads in your area are smooth.
Damon Harris
66 912 coupe
Old 07-11-2006, 01:03 AM
Toe out works for me too. Corners flatter, tracks straighter, no wander either and no bumpsteer.
Let's keep it a secret.
Joe
Old 07-11-2006, 08:22 PM
Zeke's Avatar
I haven't tried it preferring to use zero, which I expect toes in slightly on braking for nice tracking, but seems to turn in quick enough. I don't see what weight cars we are talking about other than Doug's which I expect is light. Don't lighter cars turn in better naturally? I guess if we are talking fully loaded Carreras, they probably could use the help at auotx and technical tracks. However, a 1/4 inch seems like a lot to me. I wouldn't want that at 120> mph.
You don't need no stinkin' quick turn in at Big Willow.
Old 07-11-2006, 09:43 PM
