Targa Leaking. What Part Is It?
Hello guys,
My targa is leaking water and getting the carpet drenched. I see it leaking from the side quarter windows on both sides. Does anyone know how to replace it and what part# it is? Thanks.
Old 01-12-2006, 04:21 PM
The part you are talking about is the 911-Targa-Automobile, order one new unit.
It leaks, cabriolets leak too. They all do that. Don't drive it in the rain.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 01-12-2006, 04:26 PM
Thanks.
Old 01-12-2006, 05:34 PM
KCinBR's Avatar
If your seals and top are in good shape there are some adjustments that can be made that may help you.
The adjustments are outlined in the following document:
http://radarhill.com/pdf_docs/targa_roof_repairs.pdf
if the link does not work just PM me with your email address and I send you a copy of the file when I get home tonight.
KC
KC
88 Guards Red Targa (sadly sold )
2005 Boxster S
1st Porsche 73 914 (long gone)
Old 01-13-2006, 02:27 AM
Thanks a million!
Old 01-13-2006, 07:34 AM
Early_S_Man's Avatar
Porsche Crest
On page 6 of the Repair pdf document ... area #10 is critical area concerning window glass leaks, where a part called a Frame Connector resides ... Left is pn 911.542.065.41, Right is pn 911.542.066.41. The parts guy at Vasek Polak called it a 'squeegee' when I ordered a pair in 1978. Rivet is pn 900.056.003.20, and countersunk M5 x 8 screw is pn 900.270.050.07. The condition of the bonded rubber part of the squeegee is critical, and a tight, snug fit of the upper front leading edge of the window glass is important to eliminate window leaks!
Here are some screenshots ... part #15 is the culprit in the first, #12, #13 & #14 in the second:
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 01-13-2006, 09:40 AM
Wow, you guys gave me all i need. My targa leaks right where #15 is. Hopefully I can fix it.
Old 01-13-2006, 11:09 AM
vizail's Avatar
Early S Man and the rest
Is there a crash course on how to install the corner connector #15 with the rivets
Cordially
Vic
Old 05-12-2007, 03:36 AM
vizail's Avatar
jinnos
Can you chare your progres and repair step by step in #15 Corner Connector?
Cordially
Vic
Old 05-12-2007, 03:39 AM
steve911's Avatar
Try this thread on fixing/adjusting window seals
My '85 911 Targa ** Hand painted center caps for sale here
RIP Warren
PCA & Rennlist member
Old 05-12-2007, 06:29 AM
vizail's Avatar
Thank's for the fast reply .
The problem I have is with the rivets that hold part #15 to the frame just the rivets , how to remove and re-instal or can I use the regular aluminum rivets(shorts).
Cordially
Vic
Old 05-12-2007, 02:07 PM
vizail's Avatar
The culprit is item #13 the rivets how to remove and how to re-install
Very sorry but I cant up load the pisture , is Item #13 in the second page of the Exploded graphic
Cordially
Vic
Old 05-12-2007, 02:21 PM
steve911's Avatar
Vic--
The existing rivets have to be drilled out and replaced with new ones upon reinstallation.
RIP Warren
Old 05-12-2007, 03:20 PM
WRONG... they do not all leak Well, maybey all but one...But I can only speak for mine, I would not be so bold as to make a statement about the other umteen thousand that I have not yet evaluated.
You must have been pretty busy, checking out all those Targas and cabriolets.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 05-12-2007, 05:38 PM
