zbph10's Avatar
Replacing a switch in the dash?
What's the easiest way to get at this switch to replace it?
Brian
Old 07-18-2006, 05:56 AM
Oh Haha's Avatar
The front trunk if you can get your hands in there. In this case, I think just emoving the clock and speedo would get the job done. They just pull out.
Pacific Blue
Wayne
Old 07-18-2006, 05:59 AM
Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
The Bentley manual states that you need to remove the clock first (using a plastic putty knife should help in that endevior). Label all wires on it and then detach them and remove the clock. Since you've already removed the knob, you now need to remove the mounting nut (which is in the dash). The switch should then push out to behind the dash. Pull it out from the clock opening in the dash, label the wires and detach them.
Have fun!
While you're in there, please let me know how many wires are attached to the headlight washer switch. Thanks in advance!
-Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 07-18-2006, 06:49 AM
zbph10's Avatar
I'll take a look at the washer switch tonight and let you know.
Thanks for the information
Brian
Old 07-18-2006, 08:15 AM
zbph10's Avatar
Couldn't get the clock out and didn't want to force it. The speedo came out pretty easy and the new switch works great.
In response to your question on the number of wires going to the headlight wiper switch it is 3, with two of them together.
Here's a out of focus picture if it helps at all.
Thanks for your help
Brian
Old 07-18-2006, 11:56 PM
