York's Avatar
A/C Relay Question
I just noticed that my '86 has a red fuel pump relay #911.615.108.01 where the A/C relay is supposed to be in the front fuse and relay panel (Bentley Fig 971-1). Does that make any sense? It seems to be working.
The A/C relay that I just ordered from Pelican does not look like it will fit into the existing socket. Do I need an adapter? I see from searching the subject that this is an updated relay.
'86 911 Sunroof Coupe
'91 Miata
'77 BMW R75/7
Old 07-19-2006, 08:26 PM
Have you checked the smuggler's box for a relay location?
Old 07-19-2006, 08:33 PM
York's Avatar
Jim,
Is that where the evaporator blower relay is located?
'91 Miata
'77 BMW R75/7
Old 07-19-2006, 08:35 PM
I don't believe there is an evaporator relay per se in an '86. Looking at the '86 wiring digram there is a relay that provides power to the entire A/C system and a second one that provides power to the front condenser blower. What isn't working on your car?
Old 07-19-2006, 08:56 PM
Is the relay you're trying to install blocky shaped, have four blade terminals (85, 30, 86, 87), a fuse on top and and the part number 911.615.103.01? If so it's the front condenser blower relay updated with a fuse. On an '86 the main A/C relay is round, red and contains a diode.
Old 07-19-2006, 09:18 PM
Non-updated style relay (no fuse).
Old 07-19-2006, 09:50 PM
ruf-porsche's Avatar
Go to Rat Shack and buy an automotive relay. It's a lot cheaper than a Porsche relay that is now made in CHina.
Old 07-20-2006, 08:07 PM
