comments for exhaust modification idea please
Hi all,
I've had a thought in the last couple of days. The Ferrari 360 has a dual stage exhaust system. At low RPM, the second stage of the exhaust is blocked off. Above a certain RPM, a solenoid is actuated which opens up a second stage, making it noisier and more free flowing. My idea was to add a second outlet to my stock banana muffler that can be opened or closed through a switch in the cabin which would activate the solenoid. This would let me have a noisy exhaust note when i felt like it at the flick of a switch. I thought that i could weld on a flange to the right side of the exhaust, with a solenoid in between the flange and the second tip. Anybody have any ideas for what type of solenoid i could use? Thanks alot, Adam
_____________________ '73 RSR Interpretation ---------------------------------- |
Crotchety Old Bastard
These already exist. Check out your local speed shop. JC Whitney sells an exhaust bipass that is cable operated, there is also a solenoid operated version.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
check summit and jegs, too. They have them for hotrods as Brian said.
I was just looking at some the other day. I think a pair was $200 - $500 depending who makes them. Cool idea., let us know how it works. Doug
1971 RSR - interpretation |
I think some 996 and 997s had solenoid valves on the exhaust.
'69 911 Targa w/ 3.2 |
coolcavaracing.com
I do like the idea, I would pay for a good solution like this...
Pål (Paul) - The Norwegian lost in Finland... 1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!) come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
The Volkswagen R32 has a vacuum-activated exhaust "flapper" that changes the tone of the exhaust when it reaches a certain RPM/Vac. Lots of people do away with so it is in the "open" position all the time.
Mike Serrone Jr. 2008 Candy White 2DR GTI DSG :: 1980 SC (Father/Son Track Toy) ///BrooklynAutoRennen | Rudtner's Racing Group | Tyrolsport |
I wonder if you could pcik up a 996/997 F360 or similar exhaust from a wreck or an update and take the flapper part out and integrate as you are talking about. Might be cheaper, probably not as nice. I bet there are a fair bit of these exhausts that get cast off for upgrades.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
StayGold808,
BMW has that too. I don't know about this on other model but 3 serrie has it, the exhaust valve. It open up at certain RPM. Street race guys has the y pipe adapter (whatever it call). You can attach a cable to it to close/open the valve. Original idea is to drive normal (close valve) and open up to blow it out. This is one of the part make you hear their car sound normal and all in the certain he blow extremely loud as he's driving a hardley.
Fat butt 911, 1987 |
Thanks for the replies you guys.
In case you didn't notice, i'm from australia, so those stores that some of you mentioned don't exist here heheh. I had the idea of finding a wrecked piece, but ferrari parts are like solid gold lol, and don't even get me started on F40 parts. I'll have a think and see what i come up with. I didn't intend to spend hundreds of dollars, more like a cheap solution to buying a new exhaust. I'll post if i get into it.
There will be something like a J C Whitney in Aust. That will be the cheapest solution.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Don't forget that when you effectively bypass the muffler, the fuel mixture really changes and everything gets leaner.
Late EFI-controlled engines can programmed to automatically correct for this, but others might not. I would think this one all the way through.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
wow.. thanks steve..
I didn't even consider that! But you are totally right. Especially since the idea was to shorten the muffler.
