Why does my A/C keep blowing a fuse?
I just got my system charged and installed a new A/C blower motor and it will run fine for a while but then all of a suddent he fuse will blow. Anybody have a similar situation?
Currently own: 1980 911SC slantnose 1991 Honda Accord -daily driver (1991 Honda Accord #2 - just because) 2003 Acura TL Type-S (2006 Honda Odyssey w/ DVD) Gone but missed: 1988 Mazda RX-7 Turbo II (1991 Jeep Wrangler Renegade) 1984 Jeep CJ-7 (1994 Chevy Blazer) 1987 Chevy Corvette (1996 Mustang Cobra) 1993 Jeep Wrangler (1995 Mustang GT Conv.) 2003 Ford Explorer Sport Trac (1987 BMW M6) Future: Hopefully not too far off Ferrari Testarossa (Lamboghini Diablo or Countach) Detomaso Pantera |
Is it the fuse that powers the evaporator fan motor AND the front condenser fan motor? If so, try putting one of the fan motors on a separate fuse. If one of the fan motor fuses blows than you will know which circuit to troubleshoot. Hope this helps.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Try changing out the AC fuse block. My AC fuse kept blowing until I changed out the fuse block (3 fuses) several years ago. Hasn't blown since. Now if I could only get the AC to work more than 9 months a year.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not. 2012 BMW 528i (wife's) 2007 Toyota FJ (rain and off road days) |
AC fuse box? Where is that located? The fuse that keeps bloweing on mine is located in the front trunk.
thats the one I had the same problem replced the three fuse block havent blown one since
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's. 2019 Silverado 6.2L |
Where is the 3 fuse block?
If you look carefully at the fuse panel in the front trunk, you will see that there are 21 fuses. There should be a 10 fuse block, a 3 fuse block and an 8 fuse block (not necessarily in that order). I think it is fuse #19 from the front that the a/c fans are wired into. Check the connections for corrosion and/or a loose fitting fuse. Pull a new +12v hot lead from the battery, run it thru a 20 amp fuse and connect one of the a/c fans to it. If the fuse powering the evaporator fan blows, then the newly installed fan has "issues" and should be checked or replaced by the shop that did the installation. If it is the front condenser fan (most likely!) then that fan will need to be replaced. The old fuse holder blocks are somewhat notorius for causing problems such as you are having. Age and corrosion added to very small fuse contact areas are usually the culprit.
Hope this helps.
on the LH (left side) driver's side inner fender wall. The electrical schematics are located right here on the PP site: http://www.pelicanparts.com/911/911_parts/911_electrical_diagrams.htm There are a few things that can "pop" a fuse. If the fuse was not popping before you replaced the "a/c blower motor", and I'm guessing that could mean either the evaporator or the front condenser motors, then go back and check your connections to see if something is shorting to ground... such as a bare wire terminal bent against the fan motor's casing. If you don't have a volt or ohm meter you could simply get a handful of fuses and try it the ...ahhh funky, way: unplug the front condenser fan motor, evaporator fan motor and compressor clutch. Turn on the system and if the fuse does not pop you know its one of the three items, then simply plug each in until you blow fuse. Not the professional approach but you'd be suprised at what can be accomplished. Other components in between, besides wires, that can cause the problem are the main ac relay in the evaporator box area (smugglers box), the front condenser fan relay, the fan speed control switch or the fan speed control resistor pack. Let us know how you do! |
See this link
http://www.pelicanparts.com/techarticles/mult_AC_faq/Mult_AC_faq-1.htm or read this A word about Fuses, circuit breakers and relays!! For several years, the factory made the same mistake on every car with a/c. When they wired the fuse board on the '76 to about '79, they wired the Evaporator. circuit together with the Front Condenser. Fan circuit. So that all the elec. load was through ONE fuse. Well since those ceramic fuses can hardly handle 20 amps. the load of 30 or 35 amps. was way too much for them. The connectors turn blue, get loose and will actually melt. Check your car and if the second fuse from the back of the fuse board is distorted see if the red/white wire is connected with the red/yellow wire. If it is, separate them and connect one of them to the next fuse which should be empty. A very good substitute for these fuses or any fuse that seems to be overloaded (that is , gets hot ) is a circuit breaker. A c.b. can be wired with a tighter connection, won't blow at the slightest provocation, and will reset itself automatically. Most all of these a/c's will have a Relay somewhere in the circuit mainly to protect the delicate switches from the high loads of the motors. Most over looked is the Factory relay located in the heater box next to the Evaporator. |
