This Way Up
rdrr's Avatar
A/C delete started
I've just started my A/C delete project and have so far removed the decklid condensor and the compressor. What's the best way to get the hoses out? Any tips?
Old 09-21-2006, 01:09 AM
see my last post:
A/C delete, nearly there............
Just carefully remove everything. I started with the compressor then the hoses- there's heaps!
I'll let you decide how you're gonna get the compressor bracket out!
Let me know if you get stuck.
Currently I've got everything out but that's not the end of it!
cheers,
Phil
84 ROW Carrera (guards red), A/C delete, Fuchs 7 + 8 x 16, Koni Adj. F+R, sway bars 20F 22R. turbo tie rods, Strut brace, brake cooling kit, C/F Recaro GT3 copies.
Old 09-21-2006, 01:52 AM
This Way Up
rdrr's Avatar
I have now removed the decklid condensor, compressor, evaporator, receiver/dryer and all the hoses (had to cut the long ones). I left the compressor bracket for now - will remove it when I change my muffler.
My car did not have the condensor in the front - at some point a condensor with a cooling fan was put in the left wheel well by PO and it was a total bastard to remove.
Being a ROW car the evaporator box was in the passenger side footwell. I pulled it out, removed the evaporator and then reinstalled the box as I wanted to keep the fan. I left everything else in the footwell in place.
Should I remove anything else from the footwell? Did I miss anything?
Total weight savings so far 26kgs. I also removed the rocker panels for another 4kgs - can't put them back on as one of the brackets rusted out. I'm still undecided if I want to leave it that way.
Took her out for a test run after all the work was done and she feels great!
Old 09-24-2006, 02:20 AM
Nice job!
I was quite surprised at how light it feels with A/C gone, spare & tools out with 1/2 tank gas.
Whack in a strut tower brace and get yourself some turbo tie rod ends.
My next move is race seat & 4 point harnesses, SSI's & M + K muffler, backdate heat, and there's nearly 10 kilos in the window washer tank.
Can you PM me with your email address?
I need to ask you something?
cheers,
Phil
cheers,
Phil
Old 09-24-2006, 02:35 AM
This Way Up
rdrr's Avatar
Hi Phil,
I just pm'd you.
Yes, weightloss feels great!
I'm thinking along the same lines as you - I've got the strut brace already and also a smaller window washer tank. M&K is on my list - luckily I already have SSis. I'm also thinking about fibreglass bumpers for further weight reduction. Maybe an IROC look, but I'm not yet sure about that. And of course race seats and harness.
Old 09-24-2006, 02:53 AM
rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
What did you guys do to fill all the holes left from removing the AC lines?
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 09-24-2006, 06:16 PM
This Way Up
rdrr's Avatar
I have not done anything yet. Some previous threads have mentioned using aluminium with some sealant or adhesive foam backing and then screwing them in. See this thread also A/C delete, nearly there............
Old 09-24-2006, 06:32 PM
rs6er's Avatar
They didn't address the little screw holes all over the car where the lines were attached. I already put a plate in where the front condensor fan was.
John
Old 09-24-2006, 06:44 PM
screw back the screws for the clamps with the rubber washers and include a metal washer
cheers,
Phil
Old 09-24-2006, 06:49 PM
rs6er's Avatar
Lots of hardware. Could I just get some rubber plugs or use black caulk?
John
Old 09-24-2006, 07:16 PM
If anyone finds rubber plugs, I'm in
cheers,
Phil
Old 09-24-2006, 07:21 PM
rs6er's Avatar
Check this out:
http://www.midatlanticrubber.com/stem_bumpers.htm
John
Old 09-24-2006, 08:08 PM
