without the car in front of me just a wild guess.
The fuse panel sections are connected by a brass rivit at some point. This connector failed partially. It you use the headlight sw it feeds backflow current to other connected light circuits into the weak fuse panel. I'd at least do a volt measurment with one of these down stream circuits with the bulbs attached to create a current draw. Or how about creating your own panel jump?
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
So the brass rivit is where you test to see If it's going to ground?
Derek Oxford PCA - Nationally Certified Instructor 2002 Boxster S ( race car) 2010 LR4 2009 GMC Sierra (Porsche Support 2011 M3 4Door |
I have nothing to add but hope you figure it out and post the result just in case I have to deal w/ it. Some of my wiring is chewed up and I have visions.......bad visions of stuff like this this.
If you've done any work on the car recently that may jiggled some wires around, you might just check there. Had a 2002 that died a few days after I had cleaned the engine compartment and had to shift some wires out of the way. So I started jiggling some wires around and got it started. Later, I went through a bunch of connections checking a cleaning them and never had the problem again. Good luck.
Jay '08 E350 Wagon '74 914 gone '72 T gone |
Air Medal or two
Kiss method ( keep it simple stupid ) please try all the simple things 1st !! then we will all move on to the next step.......please do the grounds and report back
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
It's directly below the red relay at the top of fuse 3 & 4 from the left. The pic is from my 1977. Don't know about other years.
Some of the wiring in these cars looks like it was an after thought. It's clear that the wiring of the short hood cars migrated itself in the the mid years.
That brass bar in RoninLb's picture looks like a problem indeed. David Duffield |
So have you checked the tailight bulbs yet?
1984 3.2 Carrera Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o |
Warren Hall Student
Ditto check the ground. There is a grounding terminal behind the dash near the driverside hood strut. Many of the dash electronics ground at this point. It's accessed from the trunk.
When you activate a switch that has lost ground it tends to seek ground though the path of least resistance. This often causes other electrical components in the loom to act strangely. Ground wires are brown in general. Every early car I have owned has had some type of burned wiring. Dash lighting is often a culprit. I would check for any melted wires behind the dash. The fuel pump receives current from the ignition switch which feeds current to the fuse on the fuse block and from there to the pump. I think it's fuse number four but can't remember for sure.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
Ok,
there has been mention two times about the possibility of rear bulbs being the culprit here. I know that MB Sprinter vans have problems when one puts a different bulb in the tail lite. Not sure if its a German thang but I did have a problem with my backup lights. didn't have an OEM replacement so I put in one 7057 bulb. Kerpow, blown fuse. Changed out the other bulb so that both bases where metal (not one metal & one brass) and I have no more blown fuses. Though I do have another eletrical problem and wonder if the non OEM bulbs are the cause. here's the link to my prob... cutting out?
joe ------------------ '69 911 E Targa - aka "RoxiE" |
Speaking of grounds...
Should there be (at least on my 80 SC) ground straps to the front and rear bonnet lids? Why? thanks, Jim
1980 911SC - 2nd Rebuild in Process - 2005 Porsche Cayenne Turbo - 2013 VW R ________________________ 2000 BMW X5 - 1996 BMW 530i - Toy 4 Runner (x2 or 3) - 1987 Toy Supra - 1988 Honda Si - 1984 El Camino Super Sport - MGA - MGB - Fiat 124 Spyder - Fiat 128 Wagon - 1962 Karmann Ghia - 1951 VW - 1953 Willys Jeepster w/Chevy 286 - 1995 Volvo 960 - 2006 VW GTI |
Check your fuse blocks first. I had a similar problem. I did all the troubleshooting and found this, the previous owner had messed with the fuse block connected some by-pass fuses, etc. it was a real mess. I replaced all three fuse blocks, problem solved. Check the pic below.
Mike 2002 996 911 Carrera Cab 1998 Boxster S 2002 BMW X5 1978 FJ40 Land Cruiser 2005 Jeep Liberty CRD - Diesel www.europautoparts.com Last edited by Europa Auto; 07-28-2006 at 02:58 PM.. |
I think the ground might not be good behind the dash, it looked and felt loose......i will let ya'll know
