Hi,
I have a 993 targa. Recently I have some "heating" problems If I turn the temperature button to the right ( maximum ) and I start the blower, I get hot air, which is normal. If I turn the temperature to the left ( minimum ) and I start the blower, I also get hot air, which is not normal. If I start the arconditioning, I still have hot air from the vents, except for the left vent next to the steering wheel ( the one between the steering wheel and the drivers' window ), which blows ice-cold air. So I have 1 vent bowing cold, and the other 3 vents are blowing hot. I mean HOT, not just warm. Does anyone have an idea what causes this and how I can fix it ? Thx Werner |
911 user
On an older model it would most likely be the vents jammed open on the heat exchangers.
WD40 time
Where once the giants walked now Mickey Mouse is king. My other car is also a Porsche. |
Did you ever figure out your heater-always-on poroblem? My '96 993 is doing the same thing. Thanks, George |
He only made this one post, and that was back in 2006. I don't think you'll get a reply.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
