a/c compressor options
Hi everyone,
I'm doing an air con install soon. I've been reading threads trying to find the best possible system, as i've experienced how useless the standard system is on a really hot day. Firstly, what modern compressors can i use that will fit the original mounts? if any... i'm probably going to add a front fender condenser similar to the 964 setup, in conjunction with the standard condensers. Has anybody found any better condensers which will fit under the decklid, except for the OEM part? I'd also be looking for one to go behind the front valence in the original location. I'm aware of a few websites from the US, by any chance... does anybody know places to source these parts in australia? Thanks all! Adam
_____________________ '73 RSR Interpretation ---------------------------------- |
Rob, 88 911 Turbo |
Re: a/c compressor options
![]() Quote:
Good luck! Scott
1984 Targa |
The other thing is to make sure you get the appropriately adjusted expansion valve. Seems like there is a hex key on the inside that lets you set up the point of vaporization. Something about 8.5 turns vs the 11 in the common expansion valve.
On condensers, if you have any plans to do a turbo on your car, this would be a good time to do the underbelly condenser and add a subcooler like Jim Sims did (or a procooler if you are rich).
DonMo 1984 911 Carrera Targa 3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip Columbia, SC "Go Hokies" |
WOW
An extra condenser for the a/c and a hot water tank for heat. You guys really do modify your PORSCHE.
That hot water tank was a b!tch to install!
1984 Targa |
scottb,
what condenser did you install in the fender? Is it a porsche part?
No. It's an aftermarket part from Ice Air Conditioning in San Diego, California. Not visible in the picture is a fan on the other side of the condenser.
Scott
1984 Targa Last edited by scottb; 07-27-2006 at 08:58 PM.. |
Ok,
If i was going to go with a sanden or seiko compressor, would any a/c specialist have the adapter bracket?
As far as I know, the only place to get the Seiko and an adapter is www.scottsind.com.
www.**********.com sells a Sanden compressor and adapter for $400 US www.rennaire.com sells the Sanden and adapter separately for about $320 US
1984 Targa |
Large Registered Member
Renneaire also just came out with an oversized front condensor... Also, their evaporator appears to be much bigger and hopefully more efficient...
'85 Carrera Coupe, Marble Grey #118 JP/R6 '93 Lexus SC400, '00 Ford F-150 '70 911T- 2.7 (SOLD) |
