Guest
Posts: n/a
Rear End Noise
Well it looks like my run of reliable Porsche motoring could be coming to an expensive end.
I noticed a whine has developed in the rear end, noticeable at speeds in excess of 30mph, and becoming more pronounced the greater the speed ('69T). Doesn’t seem to have anything to do with the engine as it remains when I allow the car to coast in neutral. I would certainly appreciate any help in troubleshooting this. As an aside, did the earlier cars come with LSD, and if so which models? Regards, |
Guest
Posts: n/a
Paul, I suspect it is bearing noise from low transaxle oil level, but it might be rear wheel bearings, too. Here are some recent threads you may want to read up on and consider carefully:
http://www.pelicanparts.com/ultimate/Forum3/HTML/000727.html http://www.pelicanparts.com/ultimate/Forum3/HTML/000774.html http://www.pelicanparts.com/ultimate/Forum3/HTML/000944.html http://www.pelicanparts.com/ultimate/Forum3/HTML/000903.html http://www.pelicanparts.com/ultimate/Forum3/HTML/000918.html http://www.pelicanparts.com/ultimate/Forum3/HTML/000562.html http://www.pelicanparts.com/ultimate/Forum3/HTML/000697.html ------------------ Warren Hall 1973 911S Targa |
Guest
Posts: n/a
Thanks once again Warren.
