OBD-II scanner/reader
Hello,
Anyone have any luck purchasing and using the OBD reader from pelican?
Anyone reccomend a better one or if the reader is even worth it?
It is only 150 bucks, figured what do I have to lose?
Tyler
Old 04-19-2005, 07:35 AM
POKDUB's Avatar
Look at www.scantools.net
Loads of free software will run on this OBD II box.
POKDUB
Porsche 911E
Old 04-19-2005, 08:01 AM
addictionMS's Avatar
this worked for me
http://www.autoenginuity.com/
Jim Hamilton
If everything seems under control, your not going fast enough.
Old 04-19-2005, 09:30 AM
CBRacerX's Avatar
Harbor Tools makes one that I bought - cheep and works well.
Chris
https://dergarage.com
‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8
Old 04-21-2005, 08:50 AM
Bill Verburg's Avatar
Baum tools has one that does OBD1 & 2
Bill Verburg
Old 04-21-2005, 10:33 AM
thanks for the replies
ordered one for the shop yesterday, now we need to find an old bum laptop that has a serial port and not USBs
thanks again
Old 04-21-2005, 02:16 PM
MuffinMan's Avatar
Or you could get a serial to USB converter. They are around $20-$30, I believe.
Rob Fusi
77 911S | 3.6 Varioram | Triad Muffler | B&B 9400 Cooler |WEVO everything | Big Reds | 23/33 | 22/22 sways | Polybronze | RSR shocks/struts | FM10s |
GTC Motorsports
Old 04-22-2005, 05:50 AM
Will any of these work on a porshe 993 motor? I have a euro motor from a 1995 993 and adapted the 16 pin diagnostic port on the DME. The Bosch Hammer works on scanning the DME but I am looking for a more cost effective solution. Will the AutoEnginuity program work or the scanttool for my application?
Thanks.
Old 05-26-2005, 09:54 PM
Hi code7rpd,
Wher you able to get an answer for this issue. I am in the same situation and wonder how you solved it.
Mario
'76 911 w/'97 3.6 Euro Vario Engine & Turbo body kit & TPC Supercharger
'15 GT3
Old 08-10-2006, 12:11 PM
Mario,
I was able to figure it out from the wiring diagrams and installed it prior to selling the car. I may have written the instructions down. I will see if I can find them and I will let you know - I may have posted them on this forum but I don't remember.
Old 08-10-2006, 12:41 PM
Thanks a lot...hope you find those.
Mario
'15 GT3
Old 08-10-2006, 12:58 PM
GeorgeM's Avatar
EBAY. Got my Actron for $70. Nice tool to have.
George M
'89 Carrera 3.2
'91 928GT
'76 914
'18 Macan GTS
George will this work with my engine?
Mario
'15 GT3
Old 08-10-2006, 01:01 PM
Hi code7rpd,
I found Moses thread on this issue but still have some questions.
http://forums.pelicanparts.com/porsche-911-technical-forum/150218-how-use-obdii-diagnostic-port-3-6-transplant-post2748755.html#post2748755
If you find your note it would be great, thanks again.
Mario
'15 GT3
Old 08-10-2006, 01:14 PM
ruf-porsche's Avatar
Brought one at HF for 39 bucks. Check out the diagnostic port on my cars that have OBDII All car came back with no code.
Old 08-10-2006, 03:11 PM
Don Plumley's Avatar
Originally posted by addictionMS
this worked for me
+1
Don Plumley
M235i
Old 08-10-2006, 03:37 PM
GeorgeM's Avatar
If it has the standard OBD II connector, it should work. Not sure if it works with OBD I.
George M
'89 Carrera 3.2
'91 928GT
'76 914
'18 Macan GTS
Old 08-10-2006, 06:59 PM
