newb.
eimkeith's Avatar
sure, pull the top of the flare opening toward you. Push down on the flare where it gets joined to the fender to make it meet the sheetmetal. secure with a screw. stand back and look at it. If it looks too low, push it back in some, etc.
does that make sense?
get the fender happy, then just make the bumper match it.
keith
'75 RS/RSR-look | '73 CB750 | '70 TD250B
r gruppe #436
Old 04-01-2008, 06:54 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #121 (permalink)
newb.
eimkeith's Avatar
you know what, I'll trace my template for you and mail it to you. What is your address?
keith
r gruppe #436
Old 04-01-2008, 06:55 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #122 (permalink)
Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
That's nice of you, thanks. I'll PM you.
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 04-01-2008, 06:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #123 (permalink)
Rennch on YouTube
rennch's Avatar
I got the passenger side tacked, seam welded, then ground down. It's really smooth and nice...probably my best welding work. (Which isn't saying much).
I should note that I welded it from the inside to reduce the amount of grinding I'd have to do on the outside.
I'll probably spend some time with a hammer and dolly shaping it a bit more, but I'm happy with how it turned out so far.
I'm a little intimidated by creating the filler panel for the bottom, and getting each side symmetrical. I guess I'll just take a lot of measurements....
On the bench:
Some perspective shots:
And finally the very nice seam on the inside...especially compared to what it was.
Michael O'Neal -
Old 04-06-2008, 07:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #124 (permalink)
Gillies's Avatar
Another good thread to subscribe to !!!
Gilles...
1970 Targa 911T
Old 10-18-2010, 01:46 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #125 (permalink)
Brando
quattrorunner's Avatar
Sub
Old 07-07-2011, 08:31 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #126 (permalink)
Hi did you have the same for the front ?
It will be great ))
This is how we (Zuffenhaus) hang a 930 flare on a 911:
(make certain the flare is tight against the roll at the bottom of the 911 body - very important)
Disregard the outer edge of the flare you are installing - only the arch (of the wheel opening) is relevant to positioning.
First measurement (A) is from the edge of the taillight opening to the lower rear corner of the arch. Straight line dimension is 365mm.
Second measurement (C) is from the inner rear edge of the jack hole to the lower front corner (at line) or the arch. Straight line dimension is 470mm.
Now, the depth measurements!
First, depth from Fender A to Frame A (at the rounded boss of the lower bumper/valance support rod) is 325mm.
Straight line dimension of point B (top of arch) to inner frame directly behind it (over the top of the tire) is 365mm.
And Fender C to Frame C at point indicated is 330mm.
Aside from that, I try to tweak the flare up until it is similar in height to the SC/Carrera flare behind it, for good clearance when the car is lowered.
I position the flare and use 3 or so self-tapping sheetmetal screws to secure it to the original fender. I use a ziz-wheel (abrasive cutting disc) to start a cut at the TOP of the 930 flare. Then I use a pneumatic body saw to cut about 6 inches in either direction and tack as I go, down each side of the flare. If you've fit the flare properly, it will not walk or wrinkle on you and will line up at the bottom edge when you arrive there. If not, minimal tweaking is possible. Upon completion of the cutting, the old fender section will fall out (unless you've tacked it, in which case it can be motivated to displace itself fairly easily.)
That should get you a well-hung 930 rear fender flare. I'm still working on the 930 to RSR thing...
(BTW, these images/measurements are from a factory 930, in case you were wondering.)
Old 05-16-2013, 09:19 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #127 (permalink)
Brando
I used the cut n weld as you go method on one of my front fenders and regular cut off then butt on the other side. Did the cut off then butt first and had a harder time with it. With the flare screwed on in three spots and nicely aligned its easy to use a cut off wheel and push the flare and cut off fender in just enough to spot weld as you go. Then the old flare just pulls out like it wanted to be out. Super simple. Just make sure it's all in the right spot. Really cool.
Turbo powa!
1977 911s. it's cool
Old 06-12-2014, 11:41 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #128 (permalink)
Ferrino's Avatar
Great thread - in particular the reference measurements taken from a factory 930 for the rear flares. Does anyone have analogous measurements for the front flares, please?
Old 11-24-2014, 10:42 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #129 (permalink)
Gillies's Avatar
Suscribed - great thread
Gilles...
1970 Targa 911T
Old 11-16-2018, 10:04 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #130 (permalink)
