Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
I just flipped the thing and did a "magnet test" on it. It looks like the bottom portion of the flare (where the turbo flare ends and the stock bumper begins) is completely bondo. So, My inclination is to blast it all off, cut a seam, pull the stock fender out, and mate it with the bumper, which I believe to be a correct RSR bumper. That said...I'm not sure if I'm up for the metalworking, so I might just contract this one out to a body guru...
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 09-24-2007, 04:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #101 (permalink)
newb.
eimkeith's Avatar
Mike - that looks like GT Racing front fenders (if they are fiberglass) with a Getty Design bumper - the GT racing flares are supposedly "correct" in shape for early RSR/ST, while the Getty bumper is designed to be the width of the 930 flares, which are wider at the bottom front edge than the RSR flares are.
In other words, the RSR flare tapers in toward the bumper at the bottom front edge more than the 930 does. Does that make sense?
I'd put slits in the bumper and recontour the curve to match the flare, then reglass underneath to seal up the slits, if it were me. (in fact, we're doing just that at the shop shortly.)
keith
'75 RS/RSR-look | '73 CB750 | '70 TD250B
r gruppe #436
Old 09-24-2007, 04:07 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #102 (permalink)
newb.
eimkeith's Avatar
D'oh! are those metal fenders?
keith
r gruppe #436
Old 09-24-2007, 04:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #103 (permalink)
Rennch on YouTube
rennch's Avatar
Yes, they are metal fenders. Does that change your assessment? (Which was an angle I hadn't thought of). Would it help to see the underside?
Michael O'Neal -
Old 09-24-2007, 04:10 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #104 (permalink)
Rennch on YouTube
rennch's Avatar
I have been looking at some pics and have noticed that the "real" RSR does appear to have a slightly narrower front than some of the RSR bumpers. I'd rather look "authentic" anyway...
Michael O'Neal -
Old 09-24-2007, 04:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #105 (permalink)
This makes a lot of sense, they could've originally been mated to a GT Racing RSR bumper. The Getty one fits the 930 flare and contour.
Old 09-24-2007, 04:13 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #106 (permalink)
Rennch on YouTube
rennch's Avatar
So, ok...I guess my next move is to find out the width of those bumpers and see if I can find one that fits my flares. This particular bumper is made by Mark Bartosh from California.
Michael O'Neal -
Old 09-24-2007, 04:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #107 (permalink)
Rennch on YouTube
rennch's Avatar
This doesn't change the fact that the fenders have a *****load of bondo at the front/bottom. I can't even get a magnet to stick.
Michael O'Neal -
Old 09-24-2007, 04:16 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #108 (permalink)
Here are a few pics I've found here and the web that show this area. Can't be 100% sure but all these pics are real RSRs.
Old 09-24-2007, 04:29 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #109 (permalink)
Rennch on YouTube
rennch's Avatar
I would love to see a direct front shot so I could see the profile of that flare. Do you have any of those Fernando? Great pics, btw...
Michael O'Neal -
Old 09-24-2007, 04:33 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #110 (permalink)
A couple more...
Old 09-24-2007, 04:35 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #111 (permalink)
Rennch on YouTube
rennch's Avatar
it looks to me like this issue is about 50% incorrectly installed flare, and 50% flare fitted to a narrower front bumper. Either way, I think I'm going to have to get rid of the bondo.
Michael O'Neal -
Old 09-24-2007, 04:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #112 (permalink)
newb.
eimkeith's Avatar
yeah, I agree - get the filler out and re-assess.
keith
r gruppe #436
Old 09-25-2007, 06:45 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #113 (permalink)
Rennch on YouTube
rennch's Avatar
Originally Posted by milt View Post
The old skul grinding disc is just the hard fiber reinforced disc. Careful when you buy them at the home stores because some of them are made for concrete, etc. That's more likely to be confusing in the section where the cutting discs are, especailly if some jerk puts a concrete one on the metal cutting disc peg and you don't see the fine print. The labels are different colors, too. Go slow while grinding and cool with compressed air or a rag.
Now, some of your welds look like they are on top of the metal. When you grind the weld, look to see how thin you are getting. You can see when the thin part heats up and turns blue faster. You will need to reweld those areas. Next, look at the welds at night with a bright light just under the weld. If you see pin holes, reweld. The last step is to use a sandblaster to clean the slag out of those minor cracks you mention. That's just uneven welding and they are little fissures. You don't need any crap in there to covered over with primer and paint. It may come back to haunt you. You can fill some of these flaws with common solder. Make sure that is really clean of all flux, again, before you paint or skim with body filler. I actually go over my welds with lead to make sure they are sealed tight.
By the way, I did this "bright light" technique and it was great. I forgot to say thanks for this great piece of advice.
So, thanks Milt.
Michael O'Neal -
Old 02-11-2008, 12:53 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #114 (permalink)
Rennch on YouTube
rennch's Avatar
Hey...quick update:
http://forums.pelicanparts.com/porsche-911-technical-forum/401033-worst-rsr-front-flare-welding-job-ever-post3857426.html#post3857426
Michael O'Neal -
Old 03-29-2008, 09:33 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #115 (permalink)
Rennch on YouTube
rennch's Avatar
Ok guys, I need some help here. I am now faced with aligning these front flares, and it would appear, if I'm using other cars (including real RSRs) for a reference, that my bumpers are a bit too wide. In the RSR pics, it looks like the front of the flare slopes inward to meet the bumper. If I fit mine the way they are, they would be about vertical. I'm also concerned about the wheel opening...should I make it even all the way around? Take a look at these pictures, and let me know what you think.
Thanks.
I'm thinking I might trim the front bumper to be a bit narrower, and fit the flares to that. thoughts?
Michael O'Neal -
Old 03-30-2008, 01:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #116 (permalink)
Rennch on YouTube
rennch's Avatar
Anyone? Eimkeith?
Michael O'Neal -
Old 03-31-2008, 10:31 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #117 (permalink)
newb.
eimkeith's Avatar
Definitely narrow the front bumper. Most of the FRP RSR fronts bumpers are made to line up with 930 flares (which are more common in modern times), a possible exception may be GT Racing's bumper...
In any event - the bumper is too wide for the correct look. The flare, as mounted, looks just a bit too narrow to me - I'd bring it out a little bit (an inch or so) and then attack that bumper.
Just MHO.
keith
r gruppe #436
Old 04-01-2008, 05:54 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #118 (permalink)
newb.
eimkeith's Avatar
btw, the top of the front flare looks like it might need to come out a bit also. (check the martini photos in this thread) - that will help some with the leading edge.
keith
r gruppe #436
Old 04-01-2008, 05:56 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #119 (permalink)
Rennch on YouTube
rennch's Avatar
Thanks Keith. Two questions:
1. Can anyone give me a point to point width on an RSR front bumper? I'm looking for
edge of flare <----------> edge of flare
2. Can you clarify what you mean about bringing the top of the front flare out?
Michael O'Neal -
Old 04-01-2008, 06:33 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #120 (permalink)
