Rouxzy's Avatar
3.6 running rich
Does anyone know how the air/fuel mixture is adjusted on these? Is there an adustment or is it all done with the chip?
Tom
Ice Green '77 Targa 3.6 w/ Steve Wong chip
One Way To Get More Horsepower Is To Get A Bigger Horse!
"I couldn't find the sports car of my dreams, so I built it myself"
Ferdinand Porsche
Old 08-21-2006, 07:16 AM
DW SD's Avatar
Asssuming it is stock 993, it is all done with the chip. Your O2 sensor(s) could be shot, though, which would make the system slow(er) to respond.
Also, there may be a limp home mode, if your system isn't getting all of the sensor inputs properly.
What are your AFRs?
Doug
1971 RSR - interpretation
Old 08-21-2006, 07:22 AM
If it's a 964 based 3.6 it has an air flow meter that can be adjusted.
Joe
Old 08-21-2006, 07:53 AM
Rouxzy's Avatar
It is a 964 model. The O2 sensor was brand new when installed the beginning of last season.
Tom
Ferdinand Porsche
Old 08-21-2006, 09:32 AM
How can you tell it's rich?
Old 08-21-2006, 08:11 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Joe
The air flow meter has an air bypass screw that can be adjusted for idle mixure within certain boundries. This is to make sure the idle stabilizer does not max. out on either end. Other than that the mixture is defined by the O2-sensor during cruise and by a map during WOT. Nothing to adjust.
I too wonder how you came to the conclusion that it runs rich. Have you used a wideband O2 sensor such as the LM-1?
Cheers,
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 08-21-2006, 10:28 PM
Irrationally exuberant
ChrisBennet's Avatar
Hi Tom,
I just happen to have a wideband O2 sensor (LM-1) on loan from a friend this week and you owe me a ride in that bad boy...
Mixture is controlled by the computer but if the sensors aren't working correctly the motor can run rich.
Did Jerry wire up an OBD-II port on your motor?
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 08-22-2006, 12:27 AM
Jim Smolka's Avatar
If it is running rich, could also be a bad Fuel Injector. Once in the Bronco, a bad FPR was allowing fuel to go into the FPR's vacuum side and then into the intake.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 08-22-2006, 03:42 AM
Rouxzy's Avatar
I'm assuming it is running rich because the exhaust pipe has a black soot covering the inside to the point where you can wipe it out with your fingers. Plus I've noticed it lately that the exhaust smell is quite strong.
Tom
Ferdinand Porsche
Old 08-22-2006, 05:44 AM
ischmitz's Avatar
Tom
I notice exactly the same with my 3.6: Black soot in the tips and it smells (that's what people tell me who get stuck behind me for longer drives. But let me tell you - one track day and the exhaust looks shiny like on day one. It does burn those deposits off the tips just like that. The LM-1 is a very good idea. It will give you peace of mind.
Ingo
Old 08-22-2006, 06:08 AM
