jeff bryant
Guest
Posts: n/a
window rattling
the passenger side window/glass rattles when the window is up, even worse when the top is down leaving the top of the window expossed. this rattle is very noticable and i can produce the noise myself by holding the top edge of the glass when the window is rolled up, and moving it back & forth, sounds like metal rattling, but i'm not sure and don't really want to remove the panel unless this symptom is something that will get worse, or damage the window itself. any suggestions? thanks in advance.
-jeff 84 carrera cab.
Old 03-15-2000, 08:07 AM
cstreit
Guest
Posts: n/a
Remove the panel. If the window is loose, it will eventually break when you close that door. (Don't ask how I know) It only take 10-15 minutes to remove the panel. Isn't the rattling more annyoing than the 30 minutes to fix?
Old 03-17-2000, 04:39 PM
jeff bryant
Guest
Posts: n/a
i'm not sure what you mean sir. once i remove the panel, then what do i look for? thanks.
Old 03-19-2000, 05:06 PM
Rufblackbird
Guest
Posts: n/a
Whenever I drive and go over bumps on the road, my passenger side window rattles like crazy. I know it's gotta be loose. After I take off the panel, what do I do to secure the glass? My friend recommends taking it to a glass specialist, but I'm sure there must be something that I can do by myself to save me a few bucks. Thanks!
Jeff
1976 911S
Old 03-28-2000, 03:41 AM
jeff bryant
Guest
Posts: n/a
i agree, there has to be simple answer...anyone? anyone? bueller...?
Old 03-28-2000, 04:41 AM
paulhagedorn
Guest
Posts: n/a
not sure exactly what would apply to your cars, but i am guessing that there would be two or three adjustment places for the window track. one should be at the very bottom of the door, another should be at the left corner of the door with you looking at it from inside the car...if passenger, opposite if driver's side,
and there might be one on the right side.
Hope this helps,
Paul
Old 03-28-2000, 10:39 AM
jeff bryant
Guest
Posts: n/a
what about the window regulator bolts?
Old 03-30-2000, 02:38 PM
