MAGA
Tim Hancock's Avatar
Ronin, here is a pic showing the "generic" industrial bearing numbers for the rack. Any bearing supply house will be able to look them up and come up with a replacement. I got mine from a local well stocked NAPA store. I found the exact same bearings in a MSC (industrial supply company) catalog also.
Here is a link to my original post on steering rack bearing replacement.
SC Steering Rack DIY Bearing Replace
The ball bearing pictured above is what was causing my problem. It was worn to the point that it would allow axial movement up and down of the pinion shaft of about 1/8". This allowed the pinion teeth to travel up or down before actually DRIVING the rack back and forth.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 08-23-2006, 08:49 AM
Originally posted by na2ub
I got the upper shaft bearing and bearing seals..
perfect.... thx
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-23-2006, 11:46 AM
thx Tim.. i somehow missed your info before.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-23-2006, 11:48 AM
